IAC housing screws
Old Mar 13, 2015 | 05:38 PM
Veaceonee's Avatar
Car: 88 GTA Notchback
Axle/Gears: don't know
IAC housing screws
Pulled off the throttle body today to start tearing it down and clean it. Noticed there are 3 broken screws, and I am sure the others wont come out without a fight. What size screws would replacements be?
Old Mar 13, 2015 | 07:07 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: IAC housing screws
heating them up with a propaine torch and soaking down with pb blaster will elp loosen the snapped off ones. hopefully you have enough to grip with vice grips. IRC the are metric fine thread 4mm cant recall the length measure from under the head to the tip of the screw.
Old Mar 13, 2015 | 07:08 PM
rusty vango's Avatar
Car: 86 IROC
Engine: 5.0 TPI
Transmission: 700-R-4
Axle/Gears: 2.73 open
I have repaired 6 of these lately. heres how I did it, first heat it with a torch or heat gun.spray it liberally with "PB blaster". let it soak for a few hours. then you heat it again and CAREFULLY work out the remaining screws. the trick is, aluminum expands at a different rate than the steel screws. so they let go rather easily. sometimes , if your lucky. there enough of the screw left sticking up to get a vice grip on it . if not you can weld a nut to the broken screw, and get it that way (damn tedious. though) once you have them all out ,you will notice some are a bit longer than the others. you can get replacements at any well equipped fastener store. I recommend allen head replacements. I hope this helps .and good luck, youre gonna need it.
Old Mar 13, 2015 | 07:45 PM
Veaceonee's Avatar
Thanks for the tips. I will give it a go this weekend. To bad the billet housings with the water jacket delete is so expensive.
Old Mar 13, 2015 | 09:03 PM
Car: 86 IROC
Engine: 5.0 TPI
unless you live in a hot dry climate, the heated TB is nice to have, it keeps the TB from icing up. and at first, the TB rebuild is daunting. but once you get into it its really simple
Old Mar 13, 2015 | 11:16 PM
Veaceonee's Avatar
Arizona is the text book definition of hot and dry
Old Mar 13, 2015 | 11:22 PM
Car: 86 IROC
Engine: 5.0 TPI
agreed ! I live in the smoky mountains. here its cold and damp. a heated TB is nice to have in this climate. I have friends that have done the TB mod on their cars with not so pretty results , some mornings
Old Mar 18, 2015 | 12:47 AM
Veaceonee's Avatar
got the IAC housing off and it broke . think it is repairable? When these pictures were taken I had cleaned it all up and put the IAC back in already.
Old Mar 18, 2015 | 05:39 AM
Car: 86 IROC
Engine: 5.0 TPI
nah, its time to get another one.just be careful and get the screws out
Old Mar 18, 2015 | 06:00 AM
Veaceonee's Avatar
Screws are out. Holes have been cleaned out. Anyone got a spare housing lying around?
Old Mar 18, 2015 | 07:06 AM
Bob88GTA's Avatar
Car: 88GTA
Engine: 5.7TPI
Sorry it broke.
How bad was it carboned up in there?
Old Mar 18, 2015 | 07:08 AM
Car: 86 IROC
Engine: 5.0 TPI
if you cant find one, call up "hawks third gen" and get one from bruce
Old Mar 18, 2015 | 03:39 PM
no new tires's Avatar
Car: 88 IROC-Z
Engine: GEN 4 LY6 (going forged 408)
Transmission: 60E (going RPM LEVEL 6 4L80E)
Axle/Gears: 7.5" 3.42 (staying...)
IAC housings on ebay are like $90+
Old Mar 18, 2015 | 03:45 PM
Car: 86 IROC
Engine: 5.0 TPI
a fine reason to not buy from "fee bay"
Old Mar 18, 2015 | 04:04 PM
Veaceonee's Avatar
Originally Posted by Bob88GTA
Sorry it broke.
It was pretty bad. But it cleaned up fairly easily.
Im going to try with what I have. I think it will work because the IAC housing is still intact. It will just look like crap.
Old Mar 18, 2015 | 06:23 PM
Veaceonee's Avatar
Update: put the IAC housing on with new bolts. Made sure the broken bolt hole had a washer on top and was really tight. Drove it around, runs like a champ.
I don't intend to leave it like that, but at least I will still have use of the car until I can find a replacement.
Old Mar 19, 2015 | 06:53 PM
1BADZ28SD's Avatar
Car: 1991 Camaro Z28
Engine: 5.7Liter HSR
i have and iac housing also have the bolts brand new stainless steel
Old Mar 15, 2016 | 10:37 AM
Galaxie500XL's Avatar
Car: 1988 IROC-Z
Transmission: T56 swap ongoing
Axle/Gears: 2.77 9-bolt Posi
Not intending to threadjack, but I've just pulled my throttle body apart for new gaskets/cleaning. The bolts that hold the IAC housing on are severely corroded, and I'd prefer not to reuse them.
Where did you get stainless bolts, and what size are those bolts?
Old Mar 15, 2016 | 10:38 AM
Car: 1988 IROC-Z
...and, I just realized this thread is over a year old, not a few days old.
Sorry!
Old Mar 16, 2016 | 01:10 AM
1BADZ28SD's Avatar
no problem i got them as a kit ... dont know the size but i have some oem bolts for the housing
Old Mar 16, 2016 | 01:03 PM
Car: 1988 IROC-Z
Would you be willing to part with a set? These are so corroded, I'm reluctant to reuse them.
Old Mar 16, 2016 | 02:05 PM
1BADZ28SD's Avatar
sure i can spare a set just to be clear these are oem not stainless steel
Old Mar 16, 2016 | 02:17 PM
Car: 1988 IROC-Z
Gotcha...as long as they're in good condition, I'd be far better off. Some of these I have, I'm surprised I was successful in removing from the throttle body without them snapping off, and am concerned a couple of them could break when reinstalling them.
How much would you want for a set to ZIP 37918?
Old Mar 17, 2016 | 01:16 PM
1BADZ28SD's Avatar
no problem pm me
Old Mar 18, 2016 | 09:39 AM
bop11's Avatar
Car: 1988 GTA
Engine: VIN F 305 TPI
Transmission: AUto
You can get stainless metric socket head cap screws or other head at McMaster Carr. www.mcmaster.com. Here in eastern, Pa if I order by noon, I get them by 5PM but that is at work. They have all sorts of stuff from sheet materials, insulation to screws nuts bolts etc. However, they do charge a bit more because they stock most.
Old Mar 18, 2016 | 10:00 AM
Car: 1988 IROC-Z
That's great information. What size are these bolts? I've not yet found that information anywhere.
Old Mar 19, 2016 | 06:59 AM
357L98's Avatar
I had the same problem with mine. I took one of the screws to Ace hardware and matched it up. Don't remember what size it was, but they had them.
Old Apr 18, 2016 | 07:45 AM
Car: 1988 IROC-Z
Well, had to go to south Georgia for some work, stopped in a place in Atlanta---and now I have 100 stainless steel bolts for the IAC. I only needed 7....the only difference other than material is they are allen head, rather than Torx.
Old Apr 18, 2016 | 09:48 AM
bop11's Avatar
Car: 1988 GTA
Transmission: AUto
SHould be able to get them at McMaster.com
Old Aug 20, 2018 | 07:27 AM
Bob88GTA's Avatar
Car: 88GTA
Engine: 5.7TPI
Hey Galaxie.. I know this is old but do you still have any of these. I need 7....and what size are they!
Thanks\Bob
Old Aug 20, 2018 | 09:17 AM
Car: 1988 IROC-Z
Bob, I’m sure they’re still here...where is a good question. I’ll get back to you on that.
Old Aug 20, 2018 | 09:18 AM
Bob88GTA's Avatar
Car: 88GTA
Engine: 5.7TPI
Thanks, no hurry. I also sent a PM to you, thanks for the reply
Bob
Old Aug 20, 2018 | 12:02 PM
Engine: Lb9
Transmission: M20
@bob if you need a gasket kit autozone has gp sorensen
96-3008
Old Aug 20, 2018 | 01:25 PM
Bob88GTA's Avatar
Car: 88GTA
Engine: 5.7TPI
96-3008
Thanks Brian! 8 bucks!!
Old Aug 28, 2018 | 07:40 AM
Bob88GTA's Avatar
Car: 88GTA
Engine: 5.7TPI
New stainless screws and washers....Intake, Plenum, and Runners acid dipped. Moving on with the rebuild. Thanks for everyone's help on the screw thing!!
Old Aug 28, 2018 | 09:49 AM
ploegi's Avatar
Car: 1988 Pontiac Firebird Formula
Engine: 5.7 TPI
Wow, that cleaned up NICE!
Old Aug 28, 2018 | 10:10 AM
Bob88GTA's Avatar
Car: 88GTA
Engine: 5.7TPI
Thanks ploegi.
I wore chemical resistant gloves. Finger tips are still a little rough from handling the parts. I'm happy with it.
Old Aug 28, 2018 | 12:46 PM
Ty92Z's Avatar
Car: 1992 Z28 1991 RS
Engine: LB9 LO3
Transmission: 5 speeds
I just googled “how to acid dip” to read up on the process and see if it was literally dipping in acid. I was not sure of what type of acid to use, where to purchase or how to keep from burning off my flesh. Well... Google thought I wanted to know how to dip acid, as in LSD. So Bob, can I trouble you for a quick overview of your materials and the process you used?
Old Aug 28, 2018 | 01:04 PM
Bob88GTA's Avatar
Car: 88GTA
Engine: 5.7TPI
Actually Ty, I used the wrong terminology when I said "dipped." I used these two products. The White Lightning brushed on first and watched it foam. Hand brushed the tough spots, (wear goggles/glasses and gloves) Rinse, repeat, Rinse, repeat. Then I sprayed on the Eagle I, let sit, rinse repeat until I got them looking good.
Old Aug 28, 2018 | 01:12 PM
Ty92Z's Avatar
Engine: LB9 LO3
Perfect, thanks.
Old Aug 28, 2018 | 01:26 PM
scooter's Avatar
Car: 92 Firebird
Engine: 4.8 LR4
Axle/Gears: 3.45 9 Bolt
Why did you use the Eagle 1 after the other stuff, out of curiosity? Seems redundant since they are both acid cleaning products
Old Aug 28, 2018 | 01:31 PM
  #42
Bob88GTA's Avatar
Car: 88GTA
Engine: 5.7TPI
Scooter,
The White Lightning took off the grease and stains. Then the Eagle I was more/less a "finish it off" type thing. My parts weren't that bad to begin with.
Old Aug 28, 2018 | 07:57 PM
  #43
Bob88GTA's Avatar
Car: 88GTA
Engine: 5.7TPI
86IROC112
Nov 27, 2015 09:54 AM
gta892000
Sep 16, 2015 12:37 AM
Magman
Sep 14, 2015 01:30 AM
greenyone
Sep 8, 2015 08:41 PM
greenyone
Sep 2, 2015 03:39 PM
