REALLY doesn't like to idle when cold...
Old Jan 29, 2019 | 11:29 PM
micktroup's Avatar
Car: 1991 Z28 Camaro
Engine: 5.7L V8
Transmission: auto
My 1991 Z28 with the 5.7 has just had the timing reset and everything else looks ok, but it HATES to idle when cold. I have to keep the revs up and nurse her until it goes into 'closed loop'- then it seems to idle fine. It will NOT, under most circumstances, idle when you first fire it up. I do see a sensor right above the starter on the block that does not have a wire going to it- could that be a factor? Thoughts??
Old Jan 30, 2019 | 11:04 AM
Aviator857's Avatar
Car: 1989 Firebird
Engine: 5.7 LS1
Re: REALLY doesn't like to idle when cold...
I would verify the IAC (Idle air control) valve is working right. It may not be able to open your throttle up enough for cold idle. The other thought would be to reset the MAF buy unplugging it, cranking it, shutting down, plugging it back up and running it.
Sensor above the starter is probably the oil pressure sender. Also make sure the timing advance is still hooked up.
Sock distributor?
Old Jan 30, 2019 | 11:33 AM
vinny R's Avatar
Car: 1991 Z28
Axle/Gears: 3:42 Auburn
Sock distributor?
His sig says it's a 91 so he would not have a MAF, it is a speed density system, MAP
Yes check your IAC and you may want check the CTS which is on the front of the intake manifold. Maybe it is sending a hot reading to the ECM and therefore not going to start mode.
Did this problem just start after you changed the timing?
1986iroc350
Jan 25, 2015 02:05 PM
Project 3.4 Camaro
Mar 23, 2010 07:58 AM
chevyracingrox
Jan 14, 2009 12:28 PM
Aaron's 87
Apr 14, 2002 03:15 PM
Dana'86_305
Carburetors
Mar 5, 2001 01:41 PM
