charcoal canister air connection routing help
Old Jul 30, 2019 | 04:50 PM
LiquidBlue's Avatar
Car: 90 Formula / T-tops
Transmission: MD8
guys, i took just enough photos back in March to put this evidence together. where does the short line on top get connected? or am i totally out of whack? i know the longer hose gets routed out the bottom of car, but can’t seem to recall a connection for the top shorter one. is it just open air?
Old Jul 30, 2019 | 05:41 PM
rt66er's Avatar
Car: 1990 Pontiac Firebird Formula
Engine: L31 350 TPI
Transmission: Tremec TKX
Axle/Gears: 3.23 Posi
Re: charcoal canister air connection routing help
This might help...
RBob's Avatar
Car: check
Engine: check
Transmission: check
Take a look at the top of the canister, IIRC, it is molded in 'AIR'. Or something of that nature.
On a '90 that T hose setup fits into the open fender area. One hose up, the other down.
RBob.
Old Jul 30, 2019 | 05:46 PM
LiquidBlue's Avatar
Transmission: MD8
RBob.
yes, this is the “air” connection that i am questioning. i know one side goes down into bottom of car, it’s the shorter side of the tee that seems out of place. is it also exposed to atmosphere?
Old Jul 30, 2019 | 10:18 PM
jczoka's Avatar
Car: 1991 Z28 5spd
On my 91 TPI, the port labeled "AIR" is open to the atmosphere. It has a dust cap on it that allows air to enter during purge but keep water and such from getting in.
Old Jul 31, 2019 | 08:04 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Yes, the long hose goes down, the short hose goes up.
RBob.
Old Jul 31, 2019 | 08:05 AM
LiquidBlue's Avatar
Transmission: MD8
Yes, the long hose goes down, the short hose goes up. RBob.
Thanks! what is the purpose of "Air" - is it to dump fuel or to suck in air?
Old Jul 31, 2019 | 10:34 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
When the canister isn't being purged it allows air to exit the canister. This is due to fumes entering from the gas tank.
During a purge cycle it allows air into the canister to replace what is purged into the engine.
RBob.
Old Jul 31, 2019 | 10:45 AM
LiquidBlue's Avatar
Transmission: MD8
RBob.
huh, wonder why GM felt the need for 2 hoses - one up and one down. I was thinking if fuel was exiting the up hose could facilitate preventing vapor lock, but would the reverse be true?
Old Aug 4, 2019 | 02:27 PM
jjz109's Avatar
Old Aug 5, 2019 | 10:02 AM
LiquidBlue's Avatar
Transmission: MD8
what year is your car jjz109?
Old Aug 5, 2019 | 01:23 PM
jjz109's Avatar
1990 5.0 liter 305 TPI
2012sergen11
Carburetors
May 25, 2017 07:22 PM
TylerSteez
Mar 14, 2017 04:21 PM
Gumby
Jun 16, 2011 02:57 AM
