L98 Will not crank again!
Old Aug 24, 2019 | 01:16 PM
Hawgtied's Avatar
Car: 1988 IROC "The Duece"
Engine: 5.7 TPI L98
My L98 TPI equipped camaro has good spark, has injector pulse verified with a noid light, has good compression but will not fire. I had it running last week and just wasn't right. I pulled the dist cap and found it was way out on the timing. I corrected the timing and now it will not run at all and it will only occasionally pop out of the intake. Timing mark lines up to zero when #1 cylinder is at TDC. Verified firing order and plug wire connections. Verified rotor position is at #1 when at TDC. Used an HEI spark tester to test for spark and i have good blue spark. what am i missing?
I' m thinking of pulling the driver side valve cover and check again TDC and verify the valve are in the correct position to eliminate of verify a timing chain issue.
Any thoughts? i need this car to be running so i can drive it when its not 150 degrees outside and enjoy it!
Old Aug 24, 2019 | 02:39 PM
irocnroll89's Avatar
From: previously OKINAWA JAPAN,georgia, now new england
Car: 1989 IROC--1989 T/A
Engine: 5.7 TPI in both
Transmission: W/C T-5 in both
Axle/Gears: B/W 3.27 in both
Re: L98 Will not crank again!
Does the fuel pump prime for 3 seconds when the key is first put in run? I would look at fuel first, with what you have said. Try start fluid squirt in T/B.
Old Aug 24, 2019 | 03:08 PM
Hawgtied's Avatar
Engine: 5.7 TPI L98
Yes I forgot to mention I have 44psi fuel pressure with t he key on. Car backfired through the intake when i sprayed starter fluid in there and turned it over.
Old Aug 24, 2019 | 04:34 PM
maks10's Avatar
Car: 1990 Trans Am
Engine: 5.7 350 HSR afr195 xfi268
Axle/Gears: 3.08 posi
Since it ran atleast some what before timing was done, Im with you on verifying tdc.
Old Aug 27, 2019 | 08:34 AM
chrias's Avatar
If it's backfiring through the intake the timing is way off. Have someone crank it while you turn the distributor in one direction until it starts or you can do it yourself. You will hear the difference in the way the motor spins. If it's slowing down turn it in the other direction.
Also ohm your injectors to ensure you don't have a bad one. They should read around 16 ohms. 10 or less is junk and the ECM will shut down that bank of injectors and the car won't start. If you don't have a multimeter disconnect each injector one at a time and try and start it. When it starts, you've found the bad injector.
Old Aug 27, 2019 | 01:59 PM
tealman92's Avatar
Car: 1992 Z28
Engine: 383
Sounds like you have the distributor off by 180 degrees. You can be tdc on intake stroke and the exhaust stroke.
Old Aug 28, 2019 | 09:07 AM
Hawgtied's Avatar
Engine: 5.7 TPI L98
I will check the TDC again and the injectors when I get a chance. Thanks for the input everyone. Its very helpful to have this forum to lean on when needed.
Old Aug 28, 2019 | 09:30 AM
Abubaca's Avatar
I'd check to see if it's off 180. I've done that before, lol. ....beyond that, did you disconnect the EST (?) when adjusting timing? If not, the computer will just compensate for every physical adjustment you make.
I think it's called the EST. Tan wire, that on my 89 was along the passenger fender.
Old Aug 28, 2019 | 10:42 AM
Aviator857's Avatar
Car: 1989 Firebird
Engine: 5.7 LS1
Have you tried setting the timing back to where it was? I would suspect that the timing mark on the crank/balancer is not right. or if you had the wires off you got them one set over.
You verified spark after changing the timing right? It seems alot of people have had pick up coils go bad after working in that area.
Old Aug 30, 2019 | 12:11 PM
86White_T/A305's Avatar
Car: 1987 TransAm Ttop
Engine: 2005 LQ4
Transmission: Ls1 T56
Axle/Gears: 3:54
Another thing I would check is the distributor hold down. I had this happen long ago and found that the hold down bolt was tight but the shiny chrome piece itself was bent being a poorly made bracket. The distributor would start turning out of whack and then no start conditions came back. Ive also had poor ground to the coil cause issues also. Its always the little things that make such big headaches
Old Sep 5, 2019 | 02:50 PM
Hawgtied's Avatar
Engine: 5.7 TPI L98
You are exactly right sir. I pulled the driver side valve cover, rotated the engine until both valves for #1 cylinder were closed, verified the timing mark was at or near zero and stuck a small piece of wire in the spark plug hole for #1 to verify the piston was where its supposed to be. I then pulled the dist cap and the rotor was pointing at #6! Pulled it out and restabbed it where it was supposed to be, put it all back together and it fired right up. Runs great! I'm glad I can finally drive it around again
Old Sep 5, 2019 | 02:58 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Great news
Old Sep 5, 2019 | 04:08 PM
Aviator857's Avatar
Car: 1989 Firebird
Engine: 5.7 LS1
Awesome... Yea I learned this the hard way at 17 before the internet and no experts around... I was ready to burn it when I finally figured out what the guy I bought the car from had done (he replaced head gaskets and couldn't get it running). I relashed the valves a dozen times convinced it was wrong.
Old Sep 5, 2019 | 05:51 PM
maks10's Avatar
Car: 1990 Trans Am
Good news! Yea that’s happened to me enough I’ll try putting plug wires 180 degrees to confirm or pull valve cover as you did. Glad it’s fixed!
Old Sep 6, 2019 | 12:52 AM
mikeceli's Avatar
Engine: LB9 305
Transmission: AT
OP, Glad you fixed it! Now for some terminology............."Cranking" is when the starter motor rotates the engine.................starting is when the engine runs on its own power.
antonov225
Jan 12, 2017 10:21 PM
83camaroking
Jul 31, 2007 04:55 AM
HuggerI-ROC
Dec 21, 2006 07:59 PM
selly
Dec 11, 2006 07:06 AM
sogabe
Nov 8, 2006 08:30 PM
