Help: 91 Gta possible bad Ecm? Not running right
Old Sep 30, 2019 | 12:52 PM
Roblen91GTA's Avatar
Car: 1991 Trans am GTA
Hello, need some help with my 91 GTA Tpi 350 i was pulling it out Sunday morning for cars and coffee it started normal and was idling normal outside warming up and i got out to close my garage when i hear the fan loudly click on and it start to run very rough. I jump in to limp it into the garage and shut it off also the engine light came on (never came on before), it was stumbling bad pulling in.
I go to jump the connector to pull codes and the car didn’t even flash code 12 just a solid engine light BUT the electric fans were on with the key on RUN and it never did that obviously.
Ive had the car for almost a decade and never had a problem this bad. The car is all original and unmolested to rule out any whacked out wires
Old Oct 1, 2019 | 11:53 AM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Help: 91 Gta possible bad Ecm? Not running right
Sounds like a bad ecm, if you tap on the ecm case does this change how it runs ?
If you need a ecm let me know I have a few for sale .
Old Oct 1, 2019 | 11:56 AM
I’ll definitely try that after work today see what happens. How much do you want for your Ecm’s? Thanks for the reply too
Old Oct 1, 2019 | 12:07 PM
Engine: Lb9
Transmission: M20
$65 shipped for a ecm
Old Oct 1, 2019 | 12:37 PM
Sounds good, I’ll report back how the tap test goes. Are the Ecms tested or known to work?
Old Oct 1, 2019 | 12:39 PM
Engine: Lb9
Transmission: M20
They are untested but if it’s bad I’ll refund you. The fact the fan is running sounds like it’s bad.
Old Oct 1, 2019 | 04:12 PM
Cool I appreciate that. Yeah I figured the fan running was a give away, plus not flashing any codes with the engine light on
Old Oct 2, 2019 | 10:32 PM
So I tried to tap on it while the car was running and there was no change, i reset the battery to see if that would help it flash any codes and still nothing and not even a code 12, definitely a bad misfire to it and smell the sloppy running
Old Oct 3, 2019 | 11:29 AM
Engine: Lb9
Transmission: M20
Bummer , Sent you a pm
Old Oct 7, 2019 | 09:07 PM
Problem solved...was the ECM
tj3269
Sep 16, 2019 07:08 PM
Welsh_GTA
Nov 29, 2018 06:32 AM
I_R_O_C_Z_2_8
Mar 6, 2015 10:42 PM
wuanno
Feb 28, 2014 03:46 PM
The_Phoenix
South West Region
Aug 11, 2008 03:48 AM
