How does one Remove the Tuned Port Injection Badge/Plate on the Engine?
Old Oct 23, 2019 | 02:32 PM
Trans AM GTX's Avatar
I have a custom painted badge I'd like to replace the standard TPI plate on my 5.7L Trans AM GTA; however, having undone the 6 Alan bolts on the existing badge, it still doesn't want to come loose as something appears to be holding it at the top. Other than the 6 bolts that can be seen by looking down at the badge, what needs to be removed to remove the badge?
Old Oct 23, 2019 | 02:35 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: How does one Remove the Tuned Port Injection Badge/Plate on the Engine?
It’s just the 6 torx bolts. Use a screw driver to pry it off.
Old Oct 24, 2019 | 08:51 AM
blacksunshine'91's Avatar
Transmission: Pro-built 700R4
Its just the old gasket still doing its job. It will pry off.
Old Oct 25, 2019 | 02:56 PM
Thanks, a friend told me the same. I was surprised to hear that the badge was an integral part of the air intake so presumably I'll need a new gasket when I put the new one on right? If so, where could I get one or what should I look for?
Old Oct 25, 2019 | 02:58 PM
Engine: Lb9
Transmission: M20
gasket kit autozone has gp sorensen
96-3008
Old Oct 26, 2019 | 01:52 PM
Excellent, thanks for the info; here's a link for anyone looking in the future: https://www.autozone.com/fuel-delive.../59535_0_12080
stevek
Mar 26, 2013 06:12 AM
hydrolic144
Jul 28, 2010 04:20 PM
mark 87gta
Sep 23, 2008 07:46 PM
JayHodge
Mar 14, 2004 08:56 AM
