1991 Z28 convert w/350?
Old Nov 12, 2019 | 08:53 AM
schmettegage's Avatar
Hi, I am from switzerland and got just recently my 1991 Z28 convertible TPI.I have a question. Where there some special order possible back in 91 to europe? Why? because in my "title" there is a 350/5733 registered and on one cylinder head there is a "57" stamp. If I identitify the VIN, it says it's an 305 TPI (F-code). The car has only 30k Miles, and everything is original, as that car came from first hand.
Thanky ou for your inputs! regards Rolf
Old Nov 12, 2019 | 02:33 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: 1991 Z28 convert w/350?
Look behind the drivers side cylinder head for the block casting number. The rpo should be a lb9.
the computer chip in the ecm identifys the tune 305 or 350 off its letters called a broadcast code.
Old Nov 12, 2019 | 04:50 PM
GeneralDisorder's Avatar
Auto or manual? If it's a manual it's a 305. Auto could be either but if the VIN says 305 then that's most likely correct. The title people in Switzerland are probably to blame for the engine size discrepancy.
GD
Jtp6194
Feb 6, 2013 06:01 PM
rocksteady92rs
Dec 9, 2007 04:44 PM
abyliks
Oct 28, 2006 02:44 PM
goodtimes11
Sep 24, 2004 07:41 PM
Abird4u2nv1
Oct 21, 2003 06:23 PM
