305 vs 350
Old Sep 24, 2004 | 06:40 PM
goodtimes11's Avatar
Car: 90 eagle talon tsi awd
305 vs 350
Hey guys i have a question, how do you tell if you have a 350 or a 305 tpi is there some visual hints. Thanks
jj
Old Sep 24, 2004 | 06:48 PM
JesasaurusRex's Avatar
There sure are jimbo, what u do is pull ur heads off, and look at the bore size. If its 4"s its a 350, if its 3.720938403804293423" its a 305. Now theres also a # on the back of ur block which you can put in the computer and look up. Theres also ur VIN # for ur car which you can also run to see if its a 305 or 350. I think 305s second #/letter in the VIN is always a letter and the 350s are always 8. Could be wrong but anywayz ya.
Old Sep 24, 2004 | 06:49 PM
Oh ya if you have a manual tranny you have a 305
Old Sep 24, 2004 | 06:50 PM
83ho86tpi's Avatar
Car: trans-am
Engine: tpi
check the 8th digit of the vin. An 8 = a 350. But the only way to be sure of an engine swap is to check the engine block drivers side top where it bolts to the transmission, just 6inches from the distributor. The blocks were stamped with a 5.7 or 5.0.
snowman89's Avatar
Car: 1989 IROC-Z Camaro
Engine: 5.8L 355
Transmission: T-5 5-speed
use the vin decoder, pop off a valve cover and get the casting number off the head and search it up at mortec.com. If the motor has never been repleced the vin number will tell you what motor you have.
Old Sep 24, 2004 | 06:52 PM
THEGENERAL's Avatar
Car: 1966 impala , 1998 sebring vert,1978 buick regal turbo, 1991 chevy silverado 3/4ton 4x4 lifted
Engine: 283, 2.5,3.8 turbo 350
Transmission: powerglide,auto overdrive, th350,4L80
look on the back of the block if in the car on the drivers side right behind the head there should be an engine casting number write that down and go to ....
www.mortec.com
and look to see what you have .....as for the vin or if you have a stick shift thing thats not always accurate especially in a car thats anywhere from 12-22 years old you never know what engine has been swapped in even thou it "looks stock"....
hope this helps any more questions just ask up
Old Sep 24, 2004 | 06:53 PM
THEGENERAL's Avatar
man i gotta start typing faster....when i went to post you hadnt yet when i hit submit yours was there...LMAO
Old Sep 24, 2004 | 06:58 PM
EliteCamaroZ28's Avatar
Car: Chevy Z28
Axle/Gears: Stock axles with 3.73
emblems
on a 350 there is an emblem that say 5.7 Tuned Port Injection on the driver side rear of the car bumper.
Old Sep 24, 2004 | 07:00 PM
Is it the 8th digit, I thought it was the 2nd, my bust.
Old Sep 24, 2004 | 07:30 PM
Thanks, This guy who is selling a 350 5 speed t.a. says it a swap. Obviously im concerned is there anyway to be able to tell just by opening the hood. also do you guys have any pics of 305 and 350 tpi's thanks
jj
P.s. im not a jimbo, i'm canadian so im a drunk
Old Sep 24, 2004 | 07:36 PM
I wouldnt believe him dude, not saying hes not telling the truth just that I wouldnt trust him with out knowing for sure. Just go get the # of the block and check online. Just call him and ask him 4 the # im sure hell give it 2 u, if it checks out then go look at the car. Make sure the #s match up to the ones he gave u tho.
Old Sep 24, 2004 | 07:41 PM
83ho86tpi's Avatar
Car: trans-am
Engine: tpi
The quickest way to spot check between a 305 and 350 is to open the hood and eyeball the harmonic balancer. The 350 came with a bigger balancer.......BUT it is also possible (but not as likley) that some ding-dong swaped balancer sizes on either motor.
xkingcodex
Feb 12, 2020 07:43 PM
Jake_92RS
Jan 28, 2020 10:37 PM
Dwayne614
Sep 28, 2015 08:33 AM
theurge
Aug 21, 2015 12:46 PM
st.evel07
Aug 13, 2015 06:15 PM
