TPI Fluctuation and Stalling
Old Dec 23, 2019 | 09:14 PM
mlbfreaks2765's Avatar
Hey Everyone,
I just acquired an automatic 88 IROC with a 383, bigger cam (not sure the specs on it), Edelbrock TPI and MSD Ignition. AIR system deleted. Still has EGR but is capped off.
I've been trying to figure out this stalling/fluctuating idle issue. Google/forum search has helped me troubleshoot but hasn't gotten me quite there. The car will start up and idle just fine while in open loop. Once it seems like it goes into closed loop, the idle will fluctuate between 600-1200 RPM and the car will stall if put into gear. It'll idle and go into gear just fine if I disconnect the MAF.
What I've tried so far:
  • Check and confirm no vacuum leaks
  • Replace MAF
  • Replace O2 Sensor
  • Replace and relearn IAC
  • Set TPS voltage, adjust idle screw
  • Adjust timing
  • Reconnect EGR
Any thoughts on this would be greatly appreciated.
Old Dec 25, 2019 | 11:53 AM
ploegi's Avatar
Car: 1988 Pontiac Firebird Formula
Engine: 5.7 TPI
Re: TPI Fluctuation and Stalling
Does the car have a custom tune for running the larger motor? And mods to the ECM? Or other electronics? Getting any codes from the ECM??
Old Dec 25, 2019 | 01:25 PM
thtanner's Avatar
Car: 1989 Pontiac Formula 350
Axle/Gears: BorgWarner 3.27 Posi
If it isn't tuned she'll act all sorts of weird with a 383 and bigger cam, that's for sure.
Old Dec 25, 2019 | 06:33 PM
Thanks for the replies.
No idea if it's been tuned. If I had to wager a guess, I'd say probably not. It was throwing a few codes including the MAF and the O2 before I replaced them and reset the computer. Haven't driven it since. Anybody know of any tuning software or anything I can use to at least look at live data?
Old Dec 25, 2019 | 06:35 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Tuner pro rt is a great program. If it hasn’t been tuned you are more than likely running $32B mask.
most update to $6e 89 mask with custom builds.
Old Dec 25, 2019 | 06:46 PM
Engine: Lb9
Transmission: M20
https://www.thirdgen.org/forums/diy-...-adx-mask.html
Old Dec 26, 2019 | 09:10 AM
KyleF's Avatar
Car: 1988 IROC-Z
Engine: 5.7 TPI
Axle/Gears: 3.45
Originally Posted by mlbfreaks2765
Hey Everyone,
  • Replace MAF
  • Replace O2 Sensor
  • Adjust timing
  • Reconnect EGR
Please get a way to scan and read data. Need to see what is going on when the surge is hitting.
Old Dec 26, 2019 | 09:44 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Check the ecm and see if theres a chip adapter in it or some type of aftermarket chip with any labels on it
Old Dec 26, 2019 | 04:34 PM
BadSS's Avatar
Most of the online procedures for setting the minimal idle setting leave off disconnecting the timing connector to the distributor. To do it right, it must be unplugged while setting the minimal idle speed and TPS voltage. If not, you’ll get a roving or “hunting” idle.
If you did that, I'd double check all the engine grounds. If those checked OK, pop off the cover on the ECM and make sure the prom is properly set and not loose.
silverstang84
Jul 10, 2016 08:42 PM
anthonyjmarshal
Jun 2, 2014 07:57 AM
blue86iroc
100
May 4, 2005 05:55 PM
wanarace
Mar 3, 2003 08:05 PM
RedIrocZ-28
Aug 29, 2002 06:17 PM
