Granatelli MAF
Old Apr 25, 2020 | 01:02 PM
88ripper's Avatar
Car: 87 camaro
Engine: 88' 350 TPI
Axle/Gears: 10 bolt 3.42 Posi
Granatelli MAF
Has anyone swapped out their stock MAF with the Granatelli one. Is it worth it if the stock one is fine? Is their any considerable gain in horsepower that you notice. I don't see how effective it would be unless you modify the stock air intake assembly ?
88' camaro 350 TPI engine
Old Apr 25, 2020 | 05:11 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Granatelli MAF
They suck
Old Apr 25, 2020 | 07:32 PM
88ripper's Avatar
Car: 87 camaro
Engine: 88' 350 TPI
Re: Granatelli MAF
Glad I asked, thank you!
Old Apr 25, 2020 | 07:46 PM
Engine: Lb9
Transmission: M20
Re: Granatelli MAF
If you need a replacement maf used Bosch or Delphi has a good reputation.
Old Apr 26, 2020 | 01:30 PM
88ripper's Avatar
Car: 87 camaro
Engine: 88' 350 TPI
Re: Granatelli MAF
ok thanks. I have a Bosch now and it has worked out good so far.
Old Apr 26, 2020 | 01:36 PM
88ripper's Avatar
Car: 87 camaro
Engine: 88' 350 TPI
Re: Granatelli MAF
Have it for about 3 years + now
Old Apr 26, 2020 | 08:51 PM
Reddragon88gta's Avatar
Engine: 5.7 L98
Re: Granatelli MAF
I went with a Delphi, works good so far and the blue streak from advance auto I tried before did not work at all.
Old Apr 26, 2020 | 11:49 PM
John in RI's Avatar
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
Re: Granatelli MAF
Been using a Granatelli on an LT1 since about 2002-03, works just fine for me; I can't say I ever noticed any difference.
Old Apr 27, 2020 | 09:30 PM
88ripper's Avatar
Car: 87 camaro
Engine: 88' 350 TPI
Re: Granatelli MAF
Thanks for the replies. I'm saving my money and sticking with the one I got...
Old May 8, 2020 | 04:12 PM
Engine: Lb9
Transmission: M20
Re: Granatelli MAF
I’ve been looking into this alittle more and thought it just had a idle adjustment.
does it do more than just idle John. I guess not so bad to fool the ecm and add or subtract fueling along the same as tuning. I think I have one I need to dig out of my parts stash and look at .
Old May 11, 2020 | 08:56 AM
John in RI's Avatar
Re: Granatelli MAF
You know; I honestly have no idea if the MAF did anything at all. I bought and installed it on a mostly stock LT1 at first and added mods over time. (SLP headers, 1LE elbow, duel cats, K&N CAI, Hypertech PP+, etc... ).I've never properly 'tuned' anything so I don't have any quality feedback other than: the Granatelli didn't screw anything up !
Old May 11, 2020 | 09:51 AM
KyleF's Avatar
Car: 1988 IROC-Z
Engine: 5.7 TPI
Axle/Gears: 3.45
Re: Granatelli MAF
I would like to know what the point is on a generally stock car. MAFs are calibrated to send a certain voltage based off a certain air flow. As in, the same sensor could be put in a larger diameter housing and would still function but the voltage readings would mean a different air flow. Resulting in the need for updated MAF tables in the tune.
So what is the gain. I understand if you are going to a bigger diameter MAF and doing your own tune. Is it just better electronics that provide a more resolution? Better assembly that provides finer hysteresis?
Old May 11, 2020 | 11:34 AM
Engine: Lb9
Transmission: M20
Re: Granatelli MAF
I’ll sell you one to experiment with 😆. Looks like adjustment is from 2k up. So maybe 30gps.
Old May 12, 2020 | 11:17 AM
KyleF's Avatar
Car: 1988 IROC-Z
Engine: 5.7 TPI
Axle/Gears: 3.45
Re: Granatelli MAF
No thanks, have one in a box for my LT4 car that the PO tossed in with the "box of stuff" that came with the car. . Haven't put it on since I don't see the point unless I am having it tuned again.
iroc stangs
Jul 14, 2010 11:58 PM
88fastgta
Dec 31, 2008 06:48 AM
z 28 jari
Alternative Port EFI Intakes
Oct 16, 2007 07:12 AM
obeymybird
Dec 5, 2006 06:30 PM
TMFK
Nov 29, 2005 10:03 PM
