Code 22 91z28 350tpi
Car: 88 GTA Notch/01'WS-6 VERT
Engine: 5.0 LB-9/5.7 LS-1
Transmission: 700R-4/4L60
Axle/Gears: borg warner 3.27's
Hello all, having a code 22 with my l98 z28 ecm is new and has the horrifying code 22 checked with my modis and has No voltage reading from the tps the tps looks like it’s been replaced by previous owner the result of this code is giving me no throttle response even with the tps is unplugged any guidance would be great
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Code 22 91z28 350tpi
Upon probing the grey wire with a test light I do have power coming from the 5v volt reference are the pigtail/ connectors known to go bad ?the pin for the tps signal is broken inside the connector
Engine: Lb9
Transmission: M20
You can repin on a connector. Teter than splicing.
https://www.corsa-technic.com/item.p...category_id=83
https://www.ebay.com/itm/Delphi-Pack...4AAOSwgotcR13F
svanky10
Feb 26, 2005 10:18 PM
