Help please!!
Old Jun 1, 2020 | 11:08 PM
Mcruze1's Avatar
Help please!!
86 iroc with tpi...
So I've finally got my car to start...again and I'm having an issue with a rich start condition I have a gm tech1 and the data stream looks pretty good but heres the kicker if I unplug the maf it starts fine and seems to idle cleaner with no change to the data stream. Has anyone seen this or have any ideas to check?
Old Jun 2, 2020 | 04:09 AM
alan91z28's Avatar
COTM Editor
Car: 91/89/85/82 Z28s, 88 TA, 88/88 SC
Engine: SBC and LS variations
Re: Help please!!
with your MAF plugged in what is the airflow reading on your tech1? if incorrect this could certainly be an issue and need to deduce is it a sensor issue or truly high airflow at idle due to vacuum leak, throttle set wrong, etc
is your TPS signal reading correctly and throttle set correctly
puddingmmmmmmmm
Oct 17, 2009 02:32 PM
vetteboy86
Apr 27, 2009 06:52 AM
irocznut
May 21, 2004 11:46 AM
SARswmr
May 20, 2003 10:38 PM
Beast5spdGTA
Oct 6, 2000 12:17 PM
