s10 multi port upgrade
I have a 1991 s10 with a 2.8 v6, i purchased a wrecked 1988 camaro with a multi port 2.8 v6. My idea is to swap the intake and make the engine a multi port and turbo. So far i have a new ecm for a 1988 camaro to use. I will get a new distributor, and i will use the harness and sensors, maf etc. Has any one on here ever done this? I would like the truck to run over 100 mph in the quarter mile after i have done the turbo setup. I will be running a isky 262 cam, comp magnum roller rocker arms, hedman headers, jet under drive pulley kit. Any help info would help. Thanks in advance.
Transmission: T-5, TH350, T-5
Re: s10 multi port upgrade
I can't help any on this subject but I will say that posting in the V6 board or checking with s10 forums will yield better results.
redline_racing
Apr 5, 2007 04:58 PM
