2.8 Info
Old Dec 30, 2007 | 03:03 PM
83camaro86's Avatar
Car: 2001 Jeep 1984 S-10 daliy drivers
Engine: 1983 has a 305 1984 Trans Am
Transmission: 1983 has 350 tubo 1984 Trans Am
Axle/Gears: stock
2.8 Info
I am thing about building a strong 2.8 motor its out of a 1986 camaro. I have been looking thru the threads and just not sure what to do. I would get headers and new mufflers. Just not sure about the motor it self. And how to tune the ecm to the new stuff. All the computer stuff is new to me. I think i would go with a bigger cam and new lifters. Been looking at some roller rockers on summit. Like i said i am just thinnkg and trying to find out what i can do. A tubo is not out of the question it would just be last on my list cause i am not to sure on how to do it and where to get one thnaks for any help you can give.
Old Dec 30, 2007 | 03:14 PM
KrisW's Avatar
Car: 88 V6 'bird/89TBI bird/85 T/A
Engine: 2.8/TBI/TPI
Transmission: V8 T-5/700R4 x2
Axle/Gears: 3.42 open/2.73 open/ 3.27 9 bolt
Re: 2.8 Info
Time for you to do some serious searching around. Use the keyword "firstfirebird" and that will get you started.
I think it's pretty well agreed that starting with a 3.4 from a 4th gen is the best place to start. After that, there are a few different roads to travel.
Good luck!
Old Dec 30, 2007 | 03:22 PM
KBcobra's Avatar
Car: 92 Chevrolet Camaro RS
Engine: 3.1L V6
Re: 2.8 Info
EFI isn't that difficult to understand. I'm 16 and its very clear to me. You can only go so big with the cam before your computer goes nuts. If you want big you need to program you ECM. Turbo shouldn't be very hard if you have healthy V6, how many miles you got on it? The sticky that dave made awhile ago should help on the turbo. Your not the first and im positive not the last person to enter the world of turbo v6.
Old Dec 30, 2007 | 03:25 PM
firstfirebird's Avatar
Re: 2.8 Info
You can get cheap 1.6 rockers at a wrecking yard. Look for a 94-95 with a 3100 in it. The rockers are a direct replacement with a 1.6 ratio.
As far as a cam, GM offers the 260* adv duration with lifters for about $125, or you can call Delta cams (google them) and they can give you the same re-grind for about $100 with lifters.
Next is you need to increase the flow on the top end. Porting and a 5angle valve job really wakes up the iron heads, but is still not that great with the upper manifold design (really restrictive above 4500RPM).
If you have the fabrication skills, a FWD top end is the best, but if you are new to modifying cars you may want to start with the above mentioned mods to get a little more kick without dumping a ton of cash until you get a grip on tuning etc.
^^^ hahah, thanks Kris.
Old Dec 30, 2007 | 03:40 PM
83camaro86's Avatar
Axle/Gears: stock
Re: 2.8 Info
Like i said i was just looking in to it. The motor would be rebuild. so everything would be new. I would like to say with the 2.8 as much as possible. I already have a 1983 Camaro with a 305 so i dont want to go the v8 rute with this one. I understand that the computer system just not sure about the retuning on it.
Old Dec 30, 2007 | 03:57 PM
KBcobra's Avatar
Engine: 3.1L V6
Re: 2.8 Info
I think people use mega squirt for V6, im not goin to stay V6 very long im planning to go V8 next winter. Dave's sticky will help you alot. I would get GM service manual if i were you worth every penny.
Old Dec 30, 2007 | 04:17 PM
83camaro86's Avatar
Axle/Gears: stock
Re: 2.8 Info
Where do you get a gm service manual? I have two camaros a 1983 and a 1986 my 83 has a 305 old school style to it no computer stuff on it al all and the 86 i just got about 6 mouths ago off ebay for like 370. the only thing wrong with it was no motor i have a motor for it so i can drive it but i also have another block to start my build with.
Old Dec 30, 2007 | 04:22 PM
KBcobra's Avatar
Engine: 3.1L V6
Re: 2.8 Info
i picked up my GM 1992 manual on ebay for $80 (steal). watch ebay, they're rare, expansive and worth it.
Old Dec 30, 2007 | 05:06 PM
bl85c's Avatar
Car: '85 maro
Engine: In the works...
Transmission: TH700 R4
Axle/Gears: 3.73 posi
Re: 2.8 Info
Take a look at crane's performance cams, you won't be dissapointed. If you want to get yourself started tuning head over to the diy prom section and start reading. Here's an excellent link to get started. -> https://www.thirdgen.org/forums/diy-...uide-book.html
3rdgenparts
May 21, 2016 11:50 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
bjpotter
Oct 4, 2015 07:48 PM
Linson
Oct 1, 2015 09:50 PM
usafirebird
Sep 29, 2015 11:58 PM
