Simple Firebird SD TPI cold air mod
Old Jul 26, 2020 | 10:52 AM
rt66er's Avatar
Car: 1990 Pontiac Firebird Formula
Engine: L31 350 TPI
Transmission: Tremec TKX
Axle/Gears: 3.23 Posi
As I was working on converting my single fan to dual fan, I noticed something. When I pulled out the OE air box (cylinder?) it was obvious that this thing is pulling in under-hood air through that big hole. What made this obvious was the small chunks of hood insulation stuck to the air cleaner element. As I already had the air box out, I thought if there was some way to port ambient air to that big hole, it should be beneficial. I had the old air duct from before I converted to TPI and, low and behold, it fits perfectly in the big hole in the air box! This could then bend around the charcoal canister and suck from the fender well. I had to slightly relocate the canister to free up enough space to run the duct. Not sure if this will make that much difference, but I think it's worth a shot.
Old Jul 26, 2020 | 01:03 PM
CKone's Avatar
Car: 88 T/A, 91 Formula, 94 Firehawk
Engine: 400 Pontiac, 5.0 TPI, 5.7 LT1
Transmission: 700R4, T5, T56
Axle/Gears: 4.10, 3.42, 3.42
Re: Simple Firebird SD TPI cold air mod
Did something similar to this back in the 90’s on my ‘88, so for others it will work on the MAF cars with this canister also. As to how much it helps, I’m with you there. However getting the pickup point closer to the cooler air surely isn’t going to hurt!
Ben Thomson
Mar 3, 2017 12:22 AM
5 speed
Jan 4, 2016 11:48 AM
JerseyMark
Sep 20, 2006 04:40 PM
MightyMouse
Apr 22, 2004 09:25 PM
trans87
Jan 21, 2002 01:15 PM
