PLEASE HELP
Old Aug 5, 2020 | 10:08 AM
Tim Eaton's Avatar
PLEASE HELP
I have a 90 iroc 5.7 tpi. Yesterday I was driving and the car just shut off after bogging down and then violently backfiring. My fuel pressure is 40 with the key in the on position but immediately begins to fall off. Down to zero within 10 seconds with key still on. I had no spark at the distributor so changed the coil. Still no spark. Now I have issues with my vats system however my ignition coil and starter are connected to a switch and push button because of this. Any ideas what my issue could be? Please please help
Old Aug 5, 2020 | 12:34 PM
Tootie Pang's Avatar
Car: 1989 IROC Convertible
Engine: 350 TPI L98
Transmission: WC T5
Re: PLEASE HELP
The ignition module (ESM?) in the distributor died while the engine was running. Spark stops, fuel still goes in, does not burn, goes through, then boom out back as the engine dies and shuts down.
Old Aug 5, 2020 | 01:31 PM
mikeceli's Avatar
Engine: LB9 305
Transmission: AT
Re: PLEASE HELP
WOW! You must know TPI like the "Back of your hand"!
I thought FOR SURE, it was failed Muffler Bearings!
Old Aug 5, 2020 | 02:33 PM
GeneralDisorder's Avatar
Re: PLEASE HELP
It does sound like the ignition module is the first place to start testing.
GD
Old Aug 5, 2020 | 03:42 PM
Engine: 350 TPI L98
Transmission: WC T5
Re: PLEASE HELP
I'm not bad at TPI but I'm pretty sure because it happened to me and it went down exactly like that, Lol.
Always change the muffler bearing filter!
Old Aug 5, 2020 | 08:30 PM
Tim Eaton's Avatar
Re: PLEASE HELP
Ok so i replaced the ignition module along with the coil. They were both under warranty. Still the same. I read somewhere about the pickup coil. Could that be the cause of my issue? I measured the resistance across the 2 leads of the pickup and its open. Is this normal?
Old Aug 5, 2020 | 11:33 PM
Re: PLEASE HELP
It could be the pickup coil as well, yes. It shouldn't be open.
GD
Old Aug 6, 2020 | 09:29 AM
Badas.sbird's Avatar
Car: 1988 GTA
Engine: 404ci LS2
Transmission: 700R4 Full Manual Reverse
Axle/Gears: 3.91 Australian 9 Bolt
Re: PLEASE HELP
I have also seen the distributor gear strip many times on factory TPI motors.
Old Aug 6, 2020 | 11:48 AM
Engine: 350 TPI L98
Transmission: WC T5
Re: PLEASE HELP
Yeah, I should've mentioned the pickup also. Once you are in there better to just freshen up everything.
thizzlamich
Apr 1, 2013 08:41 PM
Cr@sH32025
Jun 18, 2010 06:35 PM
mrrilla
Jun 10, 2007 10:22 PM
Stu's Firebird
Mar 2, 2007 12:48 PM
GTA350VORTEC
Oct 24, 2004 09:58 PM
