Return line fuel pressure
Old Aug 14, 2020 | 06:24 PM
mcb55-210's Avatar
Transplanting TPI into '55 Chevy-my new fuel tank just has a nipple for attaching the fuel return line. My intent is to run hard line along the frame rails then use braided stainless from rail to the tank. How much pressure is there in the return line...will a high pressure FI hose be ok from the rail to the tank?
Mike
Old Aug 14, 2020 | 07:26 PM
NoEmissions84TA's Avatar
Re: Return line fuel pressure
I'll take a stab at this.
Theoretically, there should be very little pressure in the return line (it's open-ended in your case), but you have to cover for all conditions.
Suppose the return line got pinched or kinked somehow.
You have to spec your hose for the worst case scenario - full pressure conditions.
Old Aug 14, 2020 | 08:29 PM
Vader's Avatar
Correct. The return line should have no pressure beyond the line restriction imparted by the hose and fittings. Most EFI hose is rated to at least 80 PSI working pressure. Return fuel hose can be less. The conversions I've done were fitted with EFI hose on the pressure side and standard fuel hose (not emission hose) on the return.
Old Aug 20, 2020 | 07:24 PM
84Elky's Avatar
Car: 84 El Camino
Engine: 360 TPI
Axle/Gears: 3.42 + Truetrac, Moser 28 Spline
Just a FYI which you may already know. If you are not using an EFI tank with a baffle, count on keeping the tank fairly full to avoid loss of fuel pickup on cornering or hard acceleration.
Old Aug 21, 2020 | 09:10 AM
mcb55-210's Avatar
Thanks for the reminder....
Mike
chanrahan
Carburetors
Aug 31, 2017 07:29 PM
Abubaca
Nov 14, 2016 06:38 PM
BretD 88GTA
Nov 6, 2013 08:44 AM
Kevman
Carburetors
Jan 7, 2011 07:36 PM
