Would broken coolant temp sender cause my engine to hardly run and not idle?
SubscribeThis is probably a very stupid question. I am very impatient and apparently I destroyed the wire that is grounded to the head along with the actual ‘unit’ (coolant temp thing) while changing my exhaust headers. Not to mention, I messed up the oil tube and the dipstick will not go in. Now the car won’t idle and sounds terrible when it runs. I did remove the plugs on the passenger side for better access. They and their wires are now on correctly and in the correct place. I am no where near a mechanic and just recently started doing stuff to my car so please go easy on me. Thanks
T.L.
close
- Join DateSep 1999
- LocationColorado USA
- iTrader Positive Feedback0
- iTrader Feedback Score(0)
- Car'83 Firebird (T/A Clone)
- Engine350 with L-69 components
- Transmission700R-4, 2000 RPM stall converter
- Axle/Gears10-bolt/3.73 ..
- Liked:826 Times in 633 Posts
Yes. Happened on a Toyota my wife had. The ECM gets wrong information and cannot manage the air/fuel/spark properly..
Quote:
thank you. Going to delete this and post where I can find one lol.Originally Posted by T.L.
Yes. Happened on a Toyota my wife had. The ECM gets wrong information and cannot manage the air/fuel/spark properly.. The switch in the cylinder head between cylinder 6 & 8 is for the operation of the secondary fan only. It will not effect engine running.
Thanks for the response. I just read that on another forum as well. Now I’m very confused why it runs terribly and can’t idle. I made sure the wires were correct.
When you say wires are you referring to spark plug wire orientation?
Quote:
Yes, exactly. Originally Posted by Tuned Performance
