TPI throttle cable
TPI throttle cable
Hello all you 3rd gen Camaro lovers. I am installing TPI into my El Camino and could use some help. I am trying to install the OEM throttle cable, but it doesn't fit my firewall opening. I can enlarge the opening easily enough, my question is about the locating notch on the cable. Can anybody tell me if while standing in front of the vehicle, is it located at the 12:00, 3:00, 6:00, or 9:00 o'clock position? Thanks for the help
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
Re: TPI throttle cable
The cable notch is indexed to the passenger side of the car..... about the "10:30" position; Here is a pic:
