IAC Replacement
Old Dec 16, 2020 | 11:36 AM
Tremo's Avatar
Car: 88 IROC-Z - original owner!
Engine: LB9 with K&Ns, MSD, Foil, Taylor
Transmission: WC T-5
Axle/Gears: BW 9-bolt, 3.45 posi
IAC Replacement
Yo guys, I need to change the IAC on my 88 TPI IROC. There is no room to get a wrench on the thing. What is they best way to go about the physical removal of the old one and to snug-up the new one once it is screwed back in? Without damaging the new one. Is there a secret tool or trick? Thanks.
Old Dec 16, 2020 | 11:58 AM
Reddragon88gta's Avatar
Engine: 5.7 L98
Re: IAC Replacement
Not a bad job at all, only annoying thing is that tiny coolant hose attached to TB and a little mess of coolant when removing. Disconnect all electrical connectors for sensors on TB (TPS, IAC), vacuum hoses (look all over the TB and you will see them, one is kinda hidden below), carefully remove the clips that hold throttle/tv cables to TB, remove the 4 10mm bolts holding the TB to plenum, remove clamp that secures coolant hose to intake or TB and it should come right out. Once its out find the right wrench to break it loose and it will come right out. I would also recommend doing the TB bypass while your at it, by doing that it will keep your TB cooler while driving and really make it much easier to remove for future cleanings or repairs. I would also do a good deep clean on it while its out, really helped my GTA.
First time I did this I removed the IAC without removing TB, took awhile and beat the part up a lot, it was also hard to tighten the new one up. Had to use a huge crescent wrench. I would just do it right, might even be faster and no risk of breaking everything.
Old Dec 16, 2020 | 12:08 PM
GeneralDisorder's Avatar
Re: IAC Replacement
I got a socket at harbor freight and turned down the end on my lathe to clear whatever was in the way. Has to be a thin wall. Could do it with a bench grinder on an extension chucked in a drill.
GD
Old Dec 16, 2020 | 12:18 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: IAC Replacement
https://www.ebay.com/itm/OTC-7226-ID...QAAOxy9X5TZZ6y
Old Dec 16, 2020 | 01:38 PM
Tremo's Avatar
Re: IAC Replacement
Already did the coolant bypass.
Old Dec 17, 2020 | 10:01 PM
dan5's Avatar
Car: "Barn find" 1985 IROC-Z
Re: IAC Replacement
I use plumbing sockets like these:
Shower Valve Socket Wrench Set (harborfreight.com)
They are sheet metal sockets, so very thin. I had a set in my tool box already. If you stack them with a smaller one inside the one for the IAC hex, you can put a regular 1/2 drive socket on it for your torque wrench. It still takes a little finesse, but it works.
seventy77
Apr 7, 2009 02:13 PM
Tremo
Jul 28, 2006 02:16 PM
91redTA
Jul 24, 2006 10:51 PM
slowTA
Jul 2, 2002 10:20 PM
BlueRoc
Sep 23, 2001 12:57 AM
