TPI Throttle Plate
Subscribe
Feb 9, 2021 | 09:33 PM
Hi, Is there coolant beneath the Throttle Body Plate?
I purchase a new one and looking to install it.
Thanks,
Reply 0
Feb 9, 2021 | 09:40 PM
Re: TPI Throttle Plate
The iac housing has a coolant passage in it. But can be modified to bypass the coolant that’s not needed to heat the Throttlebody.
Reply 0
Feb 9, 2021 | 10:20 PM
Thank you for the response, I do plan on doing the coolant bypass, so I'll do it when I replace the thermostat, and hoses since antifreeze will be drained.
Reply 0
Feb 11, 2021 | 02:14 PM
Tuned Performance... You talk about modifying the throttle body to bypass the coolant passage. Just curious is there a problem with just taking the throttle body out of the coolant loop or does the throttle body need to be modified.
Reply 0
Feb 11, 2021 | 02:20 PM
Post 5 shows the modifications needed to take the tb out of the coolant system for lt1 or tpi.
https://www.thirdgen.org/forums/engi...c-housing.html
Reply 0
Feb 11, 2021 | 02:28 PM
Okay that post helps but I guess my real question is what is the issue with just disconnecting and cutting the tube ends off.
Reply 0
Feb 11, 2021 | 02:39 PM
Correct, A barb hose connector will do the same
Reply 0
Feb 11, 2021 | 02:42 PM
Reply 0
Feb 11, 2021 | 06:30 PM
No problem with TB,
I am going to replace coolant hoses and thought I would try this bypass in the process and replace the TB top plate with a cool one
Reply 0
Mar 18, 2022 | 09:25 PM
Sorry to bring this thread back to life, but I just installed a new TB plate. The back of it is smooth however the stock plate looks different. I have not done the coolant bypass on my car and was wondering if I put the new plate on without the coolant bypass will it potentially leak coolant? Hope it's not a dumb question. The stock plate didn't have a gasket and neither does the new one.
Reply 0
Mar 18, 2022 | 09:29 PM
With a new gasket I’m sure you would be fine
Reply 1
Subscribe
