LT1 throttlebody IAC housing
Old Jan 7, 2019 | 05:22 PM
tonys91rs's Avatar
Car: 91 Camaro RS
Engine: 305 TPI conversion.
just need a housing. Don’t need the whole tb
thanks
Old Jan 7, 2019 | 06:10 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: LT1 throttlebody IAC housing
93 uses a tpi screw in iac.
94-97 has the iac housing as you have shown. Here is one for cheap.
https://www.ebay.com/itm/93-97-Camar...IAAOSwPEFbi0Ex
Old Jan 8, 2019 | 03:03 AM
tonys91rs's Avatar
Car: 91 Camaro RS
thanks. im going the same route you did using this on my tpi set up now.
Old Jan 8, 2019 | 09:59 AM
Engine: Lb9
Transmission: M20
There is little clearance on the left side water outlet and the t stat housing. The last one I used was on a stock tpi. I’m not sure but there maybe clearance issues with the manifold on aftermarket bases and runners.
here is the wiring. The square 4 connector is female unlike the picture.
https://www.thirdgen.org/forums/tpi/...t-iac-use.html
hope that helps
last post
https://www.thirdgen.org/forums/tpi/...ttle-body.html
Old Jan 8, 2019 | 10:07 AM
Engine: Lb9
Transmission: M20
You can always cut the iac housing down too.
if you need a gasket kit autozone has gp sorensen
96-3008
If you have a serpentine belt setup Dayco 87662
works well to bypass the throttle hoses. It runs from the front intake coolant port to the heater control valve.
Old Jan 11, 2019 | 08:23 PM
tonys91rs's Avatar
Car: 91 Camaro RS
Although I have a 91 I’m running belt because I’m running alternator and power steering. I’m running the stock but ported tpi base and plenum
i got the housing today I dug our a couple of iac actuators I collected over the years from body part outs. I’m not sure if they will work. They both have to be mounted with screws and harness adapter. Is there a specific part number on the iac ?
Old Jan 13, 2019 | 12:58 PM
Engine: Lb9
Transmission: M20
Ac27 is one part number for the iac
https://www.ebay.com/itm/AC27-Idle-A...5.7L&_nkw=ac27
Old Jan 13, 2019 | 01:01 PM
Engine: Lb9
Transmission: M20
c4mo
Mar 25, 2014 05:36 PM
greggpenn
Apr 20, 2011 04:44 PM
Chevy86 IROC-Z
Feb 2, 2010 07:07 AM
TPI Monte SS
Mar 24, 2007 01:54 PM
