swapping out the peanut cam
Old Jan 16, 2002 | 01:10 PM
89Formula5.0's Avatar
Would i fare better swapping out the peanut cam for a 350TPI cam or LT1 cam?
The engine is a 91 305TPI with 80,000 miles on it..... and the car is automatic.
Old Jan 16, 2002 | 03:47 PM
Guest
Guest
Posts: n/a
Do yourself a favor. Check the lift first and see if its really a peanut cam or not. All you need to do that is pull a valve cover, and turn the engine over by hand. Careful measurement with a good ruler will be close enough. I'd loosen up one of the rockers just to be sure the lifter isnt getting forced shut by the valvespring.
I have a 91 engine thats supposed to be a peanut cammed engine according to all reliable sources, and its not, its the bigger one. I have a sneaking suspicion that they didnt use the peanut cam after 90 or 91.
Old Jan 17, 2002 | 06:01 PM
88irocz28's Avatar
Car: 1994 Trans Am
Engine: 5.7L LT1
Transmission: 6-speed
That's probably true. I've heard from numerous sources that GM quit using the peanut cam when they changed from MAF to speed density. Originally, that is prior to '90, the only 305s that got the L98 cams were the ones in stick cars with dual cats.
Old Jan 17, 2002 | 08:53 PM
LeftTurn1LE's Avatar
Whats a "peanut cam"? I've heard the term before, but I don't know what you guys mean.
Old Jan 17, 2002 | 11:23 PM
88TAJeff's Avatar
Car: 88 T/A
some good ideas. Pull the drivers' side valve cover. it's the easiest.
Old Jan 17, 2002 | 11:25 PM
88305tpiT/A's Avatar
Car: 2016 Ram 1500
Engine: 3.0L Diesel
Transmission: 8sp
the peanut cam is a profile of cam that GM put into most of the 305s that were made between I think 86 and 89 or so.
the bad thing about it is that the lift numbers are around .380 inches of lift while a healthy aftermarket cam is over .500
the duration is also very small and if you want serious performance out of your 305 (260+ HP at over 5000RPM) you will need to get rid of the "PEANUT"!
Old Jan 17, 2002 | 11:30 PM
Markolc's Avatar
Car: '87 IROC
Engine: LT1 350
Transmission: 700-R4
My friend Ryan gave me the best description I've ever heard of the peanut cam, he called it a warped rod, LOL. I was almost rolling on the floor.
anesthes
Mar 10, 2016 10:35 PM
beastin91rs
Oct 9, 2015 07:38 AM
gta90
Sep 15, 2015 04:00 PM
theshackle
Aug 22, 2015 06:52 PM
theurge
Aug 21, 2015 12:46 PM
