No power to fuel pump, after removing positive cable from battery.
Hey so I have a 1987 camaro 5.7L tpi and we were testing out a horn to see how it sounds, we then were taking it off and took off the positive cable while the car was running and it started sputtering and then finally died, well fast forward we find out we aren’t getting fuel pressure, and cannot hear the pump prime, we started diagnosing and we have 12v to the fuel pump relay, our fuse near the battery is good, I jumped 12v to the g terminal to the ALDL and the fuel pump turned on and I could smell gas in the engine bay. But when I put a test light at the green and white wire there is suppose to be (from what I saw on big lou’s troubleshooting) power for two seconds when put in the ON position, I do not get that, if anyone can confirm if this means it’s my ecm or not that would be very helpful, thank you
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: No power to fuel pump, after removing positive cable from battery.
Check engine light lit when key is turned to accessory position ?
I think Tuned Performance meant key in On position.
To clarify, did you say you disconnected the vehicle's battery cables to the battery while the engine was still running? Doing so can destroy electronics. The battery does more than store power to start the engine or power accessories.
Engine: Lb9
Transmission: M20
the check engine light coming on is a indicator that ecm is powered up. Re: No power to fuel pump, after removing positive cable from battery.
I will have to double check tomorrow I believe it was on for a bit when put in the “on” position but then it turned off, I remember my brother pointing it out. I will let you know tomorrow morning, thank you for responding
Okay I actually came out to check right now and the light that came on for a couple seconds then turned off was on the bottom left of the gauges, I don’t have my plastic trim that goes on the gauges so I just see the light, and on the bottom right there is a light bulb but the light doesn’t turn on, from what I believe is that the bottom right light would be the check engine light correct?
Man you guys won’t believe it the car runs, I don’t understand why it’s running but after I plugged in the computer correctly i heard the fuel pump and thought “this is new” and so I closed the switch waited a while flipped it back to “on” and heard the fuel pump again as well as had the check engine light on, I decided to crank it and it turned on after about the second try, I don’t understand what did it, was it disconnecting the computer and then reconnecting it after?
Hey guys just a quick update the car doesn’t turn on again, it ran just fine this morning and I decided to come back to see if it runs and it doesn’t , fuel pump does not prime, if anyone would have any idea as to what happened I’d be very thankful for a response
You'll need to answer Tuned Performance's question regarding if the Service Engine Soon light is on, when the key is turned to On, when the car won't start. The Service Engine Soon light is located to the right side of the instrument cluster panel. The left side light you noted might be the Fasten Belt light. Assuming the bulb works and the wiring is good, if the Service Engine Soon light is not on when the key is turned to On then the ECM is either not powering up, has a major fault, or there's a bad connection.
Yea the service engine light does turn on, just now the fuel pump does not prime, and I was able to get it started without the fuel pump priming?
Engine: Lb9
Transmission: M20
Engine: Lb9
Transmission: M20
Check a1
I will be checking the terminal today with my dad, we recently found out that our return fuel line is actually cut, I don’t know when it got cut, I think it was when we were checking the fuel pump. Will be replacing that on Monday because I ordered in a hose for it, stupid question but would that affect the fuel pump priming? Thank you all for your help I’m sure I’m close to solving this problem.
Sorry guys I had to work and didn’t have time today, I would go out right now but my said I gotta wait for tomorrow morning, I will update you guys tomorrow
I’d just like to make sure I test the ecm correctly, I am planning to use a test light and just test terminal a1 with it, is a test light sufficient?
Engine: Lb9
Transmission: M20
Correct, if it doesn’t just verify the grounds , constant hits on the ecm and accessory power.
if all that’s good is suspect the ecm being bad.
So I just tested the ecm I have no power at a1 when key is on, at b1 the test light turns on so I know it’s working I believe b1 is 12v for battery
Engine: Lb9
Transmission: M20
B1 & c16 are hot always, a6 is accessory power . Sounds like the ecm could be bad.
I understand I was just trying to say I’m sure the test light is working basically, I will do more testing, and possibly just order the ecm.
1)The engine is running
2)The engine is cranking
3)The ECM is seeing ignition pulses (with engine running or cranking)
4)Within the first 2 seconds of key on.
Simply connect the jumper end of the test light to a good ground and then connect the other end to the A1 connector. Turn the key to On and the test lamp should light for 2 seconds then turn off. Trying cranking the engine and the test light should light. No test light in those cases indicates the ECM is not powering up the circuit (ECM fault or ECM power/ground issue), you got a bad test lamp (easy to verify on a known good circuit) or you got a bad connection with the test lamp (another easy issue to resolve).
Yea the test light works I will attempt to crank and test a1 will let you know the results, if I get a replacement ecm would I use the stock prom or should I purchase another prom
Engine: Lb9
Transmission: M20
The prom doesn’t go bad often. I’d reuse your existing one.
Engine: Lb9
Transmission: M20
Need to go to c207 a clear body connector next to the ecm check pink/blk wire for power key on and ecm fuse as well.
a6 is ecm power to turn on the buttery feeds to ecm are for keep alive memory.
Engine: Lb9
Transmission: M20
All the grounds ate listed I the pinout and go to the back of the cylinder head passenger side. But if ecm is not powered that’s a concern.
Engine: Lb9
Transmission: M20
So now since I believe everything is good we will be replacing the return fuel line tomorrow and see if it turns on after that, thank you guys for helping me really appreciate it, first time posting here 🙏🏽
You previously said it was running, then not running, then running, and now not running, etc. So you've obviously got an intermittent issue as one factor. Obviously, the fuel line would need to be repaired but if it "fixes" your fuel pump run issue then it's only a coincidence.
Sorry when I said “we will be replacing the fuel line and see if it turns on after that” I meant we are gonna continuing running tests with cranking the car and possibly getting it to actually run without the thought of fuel leaking. The fuel pump also primed today.
Note, the fuel pump will not prime every single time you turn the key to On. For example: You turn the key to On and get the fuel pump prime (due to ECM powering the fuel pump circuit) for approximately 2 seconds then you immediately turn the key to off and back to on. The fuel pump prime will not occur in the second round. You must wait X amount of time with the key in the On or Off position, after the last fuel pump prime, before it will prime the fuel pump circuit again. Therefore, you can't keep turning the key to On, Off, On, Off, and see the fuel pump circuit prime each time due to the "timer" function.
I believe it could possibly still be the ecm, since it’s priming I’d like to see what happens once it turns on and runs and if it will turn on afterwards, also would like to see if it primes again tomorrow
Chakadog
Carburetors
Nov 7, 2019 03:33 PM
