Replacement Charcoal canister Alternative?
Old Apr 14, 2021 | 11:13 PM
CobraKai's Avatar
Would this canister from the Allante/ Fleetwood be a good fit for 3rd Gen 88-92 TPI? Since Ac Delco 215-613 is discontinued. These canisters are more available and have the built in solenoid. Would this be plug and play?
Old Apr 15, 2021 | 02:58 PM
ULTM8Z's Avatar
Re: Replacement Charcoal canister Alternative?
You can rebuild them... super easy... for the price of some fish-aquarium filter activated charcoal from the local pet store.
https://www.thirdgen.org/forums/tech...isters-go.html
Old Apr 15, 2021 | 06:27 PM
scooter's Avatar
Car: 92 Firebird
Engine: 4.8 LR4
Axle/Gears: 3.45 9 Bolt
What you pictured looks like it's fundamentally the same. Give it a shot
Old Apr 16, 2021 | 06:46 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
One thing to watch for is the solenoid operation. GM used both normally open (NO) and normally closed (NC) solenoids. Can tell by seeing if it passes air during key-off (or off the car). A NO solenoid will allow air to pass while an NC won't.
Mix the two up and the purge cycle won't work.
RBob.
Old Feb 15, 2024 | 07:52 PM
irocz818's Avatar
So Cobrakai, did this canister work. i just connected a bunch of lines, incorrectly, and my canister exploded. Cant even rebuild like ULTM8Z pointed out.
Chevy86 IROC-Z
Feb 21, 2015 10:02 AM
PurpleG20305TPI
Nov 30, 2012 11:48 PM
candy burple rs
Feb 24, 2010 09:30 AM
Green89IROC305
Jun 6, 2006 11:32 PM
skahide
Jul 2, 2003 01:03 PM
