Power steering impacted by braking
Old May 6, 2021 | 11:09 AM
88formula5spd's Avatar
Hey guys, I just noticed an issue over the past couple of weeks wherein hard braking causes a loss or power steering (not completely, but noticable heavier) and swerving. Additionally, turning on the air conditioning and braking at the same time causes stalling. It seems like an issue with the drive belt, considering all of these systems run off of it. How would I go about diagnosing the actual issue?
Old May 6, 2021 | 08:23 PM
NoEmissions84TA's Avatar
Re: Power steering impacted by braking
For starters:
Test the vacuum booster (behind the master cylinder) for a vacuum leak.
Also where the hose connects is a one-way check valve. Test that too.
Look for leaks/cracks/disconnected of all vacuum lines.
F-Bodeee
Mar 15, 2004 01:04 PM
Jeff Morgan
Apr 10, 2002 05:21 PM
83berlinetta
Jul 25, 2000 01:28 PM
