tpi cam replacement
Old Jun 6, 2021 | 11:46 AM
87350gtanj's Avatar
Car: 88 GTA Notch/01'WS-6 VERT
Engine: 5.0 LB-9/5.7 LS-1
Transmission: 700R-4/4L60
Axle/Gears: borg warner 3.27's
tpi cam replacement
hello all, anyone have a suggestion on a cam replacement for a stock 91 350 tpi tia!
Old Jun 6, 2021 | 12:30 PM
Vader's Avatar
Re: tpi cam replacement
Are you planning on changing only the cam, or modifying the entire valve train? Are you planning on a PROM change for the ECM? Those variables might dictate your range of choices.
Old Jun 6, 2021 | 02:38 PM
87350gtanj's Avatar
I would like to change just the cam and lifters with something suitable for stock not looking to have a chip burned for the ECM or upgrade the valve train
Old Jun 6, 2021 | 02:53 PM
ULTM8Z's Avatar
With a MAF car you could probably get away without tuning if the cam upgrade is mild. Suggest something like a ZZ4 cam. 208/221 @.050 on a 112 LSA. It'll idle and drive like stock, but give a nice power increase that will still be well matched to a TPI engine.
Old Jun 6, 2021 | 07:23 PM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
Just put one of these in a friends 91 formula 350. I really like it. I don't remember using the older cam chain sprocket but maybe we did. I'd see if you can have it made with the correct roller cam bolt pattern.
Super L98 Hyd. Roller Camshaft (EST. SHIP TIME 8-10 WEEKS) – TPiS (TPI Specialties)
Old Jun 6, 2021 | 08:37 PM
dmccain's Avatar
Car: 89 Firebird
Engine: 355 TBI
GM has one. 214-220 duration and a lil more lift than stock and it's only $100. Copy of the old 2032 cam. 9446 I think. I've read a lot of folks like it and shouldn't be too far out there on the tune. Stock 91-92 cam is what 202-207 duration? Got to be a bit of an upgrade.
tcrisp
Dec 27, 2012 01:58 PM
91camarolover
Oct 17, 2011 10:43 PM
juggaloblazed
Dec 20, 2006 10:48 PM
FOX-GTA_89
Apr 7, 2004 10:24 PM
