Plastic Gas Tank?
Old Jun 24, 2021 | 07:10 AM
wgripp's Avatar
Car: 1991 Trans Am GTA
Engine: L98(5.7 L TPI)
Transmission: 700r4(A4)
Axle/Gears: G80 RPO, 3:23s, Auburn Racer's Diff
Plastic Gas Tank?
Good morning. I have a 1991 GTA with an L98 350.
I am maintaining/upgrading my fuel system in my 1991 Trans Am L98 350 after it sat in my garage for the last four years.
How involved is it to upgrade to a plastic tank? (I have to drop the tank anyway to get to the fuel pump.). Is this a bad idea because it reduces weight over the rear axle? Is a 4th Gen F-Body tank plug-and-play? If so, what year tank will I need? What other parts will I need for the installation? Is there a better tank available?
Thanks again!
Bill
Old Jun 24, 2021 | 09:16 AM
scooter's Avatar
Car: 92 Firebird
Engine: 4.8 LR4
Axle/Gears: 3.45 9 Bolt
Re: Plastic Gas Tank?
The plastic tank is actually slightly heavier, but only a few pounds, nothing to worry about. It is not plug and play, but it fits in the space the same and the same straps. I believe the year spread is 99-02
The plastic tank swap has been covered many, many, many times. Read in the LT/LS swap forum
Myorangecamaro
Fabrication
Aug 19, 2014 05:53 PM
charliemccraney
Jan 14, 2012 08:06 PM
FreeLoader
Jul 26, 2006 11:26 AM
88_Import_Slaye
May 12, 2004 10:16 AM
Eightyninef
Jul 7, 2001 09:37 PM
