Making Underhood Fuel Lines
Old Jan 21, 2020 | 05:27 AM
rgauder's Avatar
Car: 1987 Trans Am
I'm converting from v-belt to serpentine belt on my 87. Does anybody have a list of the parts needed to build the underhood fuel lines with an fittings and braided steel line? I just need to know what an fittings to get, I know the line is an-6 that mostly gets used.
Old Jan 21, 2020 | 09:08 AM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Making Underhood Fuel Lines
Fragola 491970 and 491971
491963 and earl's 9894DBJERL
Old Jan 21, 2020 | 09:12 AM
Engine: Lb9
Transmission: M20
the rail is 14mm return and 16mm feed.
Fragola 491962
Fragola 491963
Old Jan 21, 2020 | 09:29 AM
rgauder's Avatar
Car: 1987 Trans Am
How are these hooked up? I'm not near the car.
Old Jan 21, 2020 | 09:34 AM
Engine: Lb9
Transmission: M20
It depends on where your starting the an. Since you have 85-87 hard lines you might start at the fuel rail.
saginaw 14 & 16mm to an. Then make a flex line to the hard lines on the body.
the lines on the body are male saginaw.
Old Jan 21, 2020 | 10:19 AM
IROCZman15's Avatar
Car: 1987 IROC-Z
Engine: 406 on N20 w/ EFI
Transmission: P.B. 700R4
Axle/Gears: 12 bolt w/ 3.91
I JUST removed my -8 feed and -6 return fuel lines (PTFE) from my TPI setup since I am doing the engine swap in a few weeks. If you want to buy my adapter fittings that go fromthe TPi "rail" setup, I will sell them to you. they can be seen in this photo. they are black anodized fragola fittings from Racetronix.
Old Jan 21, 2020 | 07:43 PM
rgauder's Avatar
Car: 1987 Trans Am
Shoot me a PM.
Old Jun 24, 2021 | 01:03 PM
89fast5oh's Avatar
Car: 1987 Z28 IROC
Engine: 6.2L
Bringing this thread up.
I need to make fuel lines to connect to my pro flo xt intake with LT1 fuel rails.
I have a 1987 Camaro 305 TPI.
Are the fuel lines that run up the frame rail the same sized fittings as they are at the intake, 14mm x 1.5 & 16mm x 1.5?
What are the fitting sizes right at the hard line by the strut tower?
I want to be able to have a threaded connection to the fuel lines of the car, then convert to the push and clip style of the LT1 rail.
transamice
Aug 9, 2012 01:17 PM
Jammin'Trey
Carburetors
Nov 13, 2008 08:31 PM
TraviZ
Alternative Port EFI Intakes
16
Dec 19, 2006 01:06 AM
pitzzilla
Jan 20, 2003 05:43 PM
