91 runs rough and dies
Old Jun 29, 2021 | 09:00 PM
Delong02's Avatar
Hey there, as a description as what it is doing, my car would run up until operating temperature 180°F and then it would die, if I tried to start it it would chop and run really rough and then die, after I allowed it to cool down for 30min it would start again, I read that the fuel pressure regulator could be at fault and so I replaced it, I have now run the car around for a few hours and it has been idling weird, idling high and then when I adjusted it down it would die, then finally even after I backed the idle screw all the way out it would still run at around 1600 RPM so I shut it off and reset my idle air control valve sensor, (turned key, unplugged, turned off key, plugged in) now it is back to square one of choppy idling and dieing. What do I need to do? Has this happened to anyone? (P.S. I sprayed starting fluid around all of my vacuum lines to check for a leak as far as the high idle goes)
Old Jun 29, 2021 | 09:05 PM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
Re: 91 runs rough and dies
Does it have the original injs? If so, ohm them cold then hot.
Check fuel psi and make sure it's within spec.
Have to figure out if it's loosing fuel or spark, then figure out why.
Old Jun 29, 2021 | 09:08 PM
Delong02's Avatar
Hey I have actually replaced the fuel injectors for higher lb ones and I got it tuned, as far as checking the fuel pressure I have not done that yet.
night_rider13
Jan 5, 2015 09:42 AM
lotsabirds
Apr 5, 2012 10:10 AM
jimmas
Sep 22, 2008 03:02 PM
Big Dave
Jun 22, 2008 08:14 AM
kevinz85
Jun 6, 2004 11:41 AM
