Starts but won't idle
Old Jan 1, 2015 | 10:43 PM
night_rider13's Avatar
I have a 92 with a 305 TBI. It with start but you have to keep pumping the gas to keep it alive. I think it's the eprom and would like to now what you guys think.
Old Jan 1, 2015 | 11:19 PM
antares57's Avatar
Car: 91 Firebird/88 Firebird/91 Formula
Engine: V6 3.1/V8 5.0/V8 5.0
Transmission: 4L60/700R4/4L60
Axle/Gears: 3.23/2.73/2.73
Re: Starts but won't idle
Welcome to the forums. Start by checking for vacuum leaks. Check your fuel pressure and ohm your injectors. Also check to see whether you have any codes present. Let us know what your results are.
Old Jan 2, 2015 | 10:16 AM
Fuel pressure is good. There is no leaks and there is spark
Old Jan 2, 2015 | 07:24 PM
fireburdluvr85's Avatar
Car: 91 formula ws6
Engine: 355 tpi OBDII
Transmission: 4l60E
Axle/Gears: 2.73 with 4th gen brakes
What was the pressure during idle and high rpm?
Old Jan 2, 2015 | 10:24 PM
It won't idle. And won't run will you put your foot to the floor. You have to keep pumping the gas paddle to keep it running
Old Jan 2, 2015 | 10:38 PM
Car: 91 formula ws6
Transmission: 4l60E
OK, what is the pressure while the fuel pump is running? I once had a great fuel pattern, with 2 lbs of pressure. Had to keep feathering the throttle to keep it running. For 3 months I refused to check the actual pressure. Turned out I had a Hole in the rubber line between the pump and the pick up tube is why I ask. Again, it appeared to have great fuel pressure to me. Not many people have a TBI adapter to check fuel pressure, maybe you do. That's why we have to ask what the actual fuel pressure is to assist in determining the failed component.
Old Jan 2, 2015 | 11:22 PM
antares57's Avatar
Ohm your injectors...should read around 1.3. And check the spray patterns of your injectors as well...should be conical, not dripping.
Old Jan 5, 2015 | 09:42 AM
I don't remeber the numbers I got but my friend pulled the EPROM and it runs now just idle high. Think it could be a program problem?
Orr89RocZ
Apr 25, 2016 08:28 AM
backtothe80s
Sep 5, 2015 12:39 AM
Logan Bryant
Aug 27, 2015 11:52 AM
IroczFan
Carburetors
Aug 18, 2015 05:19 AM
BurlyChev
Aug 16, 2015 09:08 PM
