TPI WIRING HARNESS
Old Aug 27, 2021 | 12:25 AM
iroc Jon's Avatar
Want a title? Post!
Car: 89 Iroc z
Engine: 5.7
TPI WIRING HARNESS
Hello, i have a 1989 Iroc-z with the 5.7L. I purchased this as a project. the previous owner removed the TPI set up. And completely butchered the wiring harness. i have a harness from a 90 TPI set up but i’m not sure if this will work. any info on this would be greatly appreciated
Old Sep 7, 2021 | 02:57 PM
1989karr's Avatar
Engine: 3.4 / 5.0
Transmission: 700-R4
Axle/Gears: 3.42 / 3.42
Re: TPI WIRING HARNESS
You'd need the ECM as well since they use diffrent setups.... that ans a MAP sensor and I think a few other sensors as well...I THIN kthe plenum might also be different.
Old Sep 7, 2021 | 06:14 PM
aliceempire's Avatar
Transmission: T-5, TH350, T-5
http://www.austinthirdgen.org/index.php?pid=19
you will need a 90-92 ecm, whatever sensors you maybe missing for a speed density(I don't know what you got for a setup) and possibly some repinning of the c207 and c100 connectors. Check that link to see harness diagrams for the 2 applications.
if you're using the cars original plenum then you'll need to add one vacuum port, and there's no mounting boss for the map sensor.
michael
17
Jun 25, 2015 08:36 PM
JayBoCC2
28
May 17, 2015 03:11 PM
windowrattler
Apr 5, 2012 11:18 AM
Mike86Z28
Jul 2, 2004 10:13 PM
