Torque Specs for Exhaust Header Bolts?
Old Nov 11, 2021 | 08:32 PM
67CK's Avatar
Car: 1967 Chevy C-10
Hello, I'm a newbie to this forum and just bought myself a "FrankenTruck," which in my case is a 1967 C-10 with an 80's era fiberglass step-side bed, an L98 ('89 or '90?) engine, and the front-end of a 1981 C-10. Anyway, it's been difficult figuring everything out on this truck (but that's half the fun, right?). I know I'll be on the forum often and looking for help. I appreciate your assistance and look forward to learning more as I upgrade and fix things on this monster. I'll also make sure to hit the "stickies" and other threads for answers before I start rapid-firing them off to the group.
For my current issue, I'm planning on changing out the plugs when I do my next oil change. In order to get better access to the plugs I plan to unbolt the exhaust headers from the exhaust manifold. Does anyone have a good reference for the torque specs on those header bolts? The closest I found was on a Corvette forum which said 20 ft lbs. Anyone have a better reference for those specs? Thanks!
The Beast
L98?
Exhaust Headers
Old Nov 12, 2021 | 11:05 AM
350Iroc89's Avatar
Car: 1989 Camaro IROC Z
Transmission: 4L60
Axle/Gears: 2.77 G80 9 bolt
Re: Torque Specs for Exhaust Header Bolts?
Get a socket like this and don't disturb the old header gasket. https://www.summitracing.com/parts/tfs-90500
I can swap a set of plugs in about 20 minutes with this thing.
Old Nov 12, 2021 | 08:36 PM
67CK's Avatar
Great idea...thanks! I think I can get some of those at Harbor Freight tomorrow.
https://www.harborfreight.com/sae-me...-pc-62305.html
Old Nov 16, 2021 | 08:46 PM
67CK's Avatar
OK, so I was able to swap the plugs out without any issues, thanks 350Iroc89 for the pass through socket idea…worked like a charm.
Now on to a bit of a concern. While plugs weren’t completely fouled, many had some small oil fouling at the end. I know I’ve got a couple of leaky Valve cover gaskets and hope that’s all it is. Any other thoughts on that? Bad rings maybe?
Old Nov 16, 2021 | 08:58 PM
aliceempire's Avatar
Transmission: T-5, TH350, T-5
Valve seals are more likely. Does it make a blue smoke puff when you first start it? If yes then it's almost completely positive the valve seals are bad
Old Nov 16, 2021 | 09:02 PM
67CK's Avatar
I’ll get my son to start it and check out the tailpipes next time. I haven’t noticed it from the cab when starting it up but haven’t really been looking for it. I do know it goes through a bit of oil and every two or three tanks of gas I have to add about half a quart…
Old Nov 17, 2021 | 08:34 AM
350Iroc89's Avatar
Transmission: 4L60
My plugs were fouling like that too to the point where it ran like crap. It would also puff smoke on a warm start up. I changed all the valve seals. It was not a fun job but it will probably be easier in a C-10 than an F-body.
Old Nov 17, 2021 | 09:36 AM
67CK's Avatar
Yeah, I definitely have more room in the engine compartment to do that…still a pain in the ***. I’ll check it out and give you update on what I find. Thanks again for the help and suggestions…
Tootie Pang
Jun 15, 2017 02:19 PM
Firebird Mess85
Jun 26, 2010 11:10 AM
Kevs87TA
Oct 15, 2002 06:55 AM
