Vortec heads, 6492 cam, TPI
Old Nov 25, 2021 | 10:24 PM
silverstang84's Avatar
Car: 88 IROC
For the engine combo gurus… how wel do you think this setup would run… 6492 cam, vortec heads, TPI on a 88 L98. I just might have all the parts to throw this combo together. Is it worth a try?
Old Nov 26, 2021 | 01:58 AM
Komet's Avatar
Car: 1989 IROC-Z
Engine: L98 350 TPI
Re: Vortec heads, 6492 cam, TPI
Specs on cam? You'll need a lower intake designed for vortec bolt pattern to use a stock TPI setup on vortec heads.
Old Nov 26, 2021 | 06:39 AM
Car: 88 IROC
I don’t have the specs on hand at the moment but it’s the same as a 2032 cam. I have the SD lower TPI for vortec heads.
Old Nov 26, 2021 | 07:00 AM
rt66er's Avatar
Car: 1990 Pontiac Firebird Formula
Engine: L31 350 TPI
Transmission: Tremec TKX
Axle/Gears: 3.23 Posi
Subscribed...
Old Nov 26, 2021 | 06:47 PM
TransamGTA350's Avatar
Car: '89 GTA
Engine: ZZ6TPI
Should run good. The SD Vortec intake will need some porting around the injector bosses and I would use larger diameter runners and a set of headers.
Old Nov 26, 2021 | 09:21 PM
Car: 88 IROC
Awesome thanks for the reply
nelson84
Oct 20, 2014 10:20 AM
unknown_host
Aug 7, 2012 11:50 AM
evo-offer
Jul 16, 2012 09:40 AM
unknown_host
Mar 22, 2012 11:01 AM
Fullofquestions
Jun 29, 2010 07:49 AM
