vortec or corvtte alu heads for 350 tpi?
Old Jul 15, 2012 | 12:54 PM
evo-offer's Avatar
Hi.
I just wondering wich would be de best / "cheapest" deal. i suppose i need a special intake if iŽll go with vortec heads? from wich year should i take corvette heads that fits 350 tpi? does they keep the low/mid torque?
iŽve find this:
http://sdparts.com/details/scoggin-dickey-parts-center/sd3816
or is their any other options if iŽll wanna go with vortec heads? any difference between vortec and stock heads btw?
Old Jul 15, 2012 | 09:38 PM
88camaroscv6's Avatar
Car: 1989 Formula, 1988 Camaro
Engine: Vortec 350 TPI, 2.8 V6
Transmission: 700r4, 700r4
Axle/Gears: 4th Gen 3.43 Posi, 3.43 Open
Re: vortec or corvtte alu heads for 350 tpi?
i just ordered that intake, vortecs flow better than the stock heads, im also going to swap in the lt4 hot cam with ls6 beehive springs, look around the forums theres a lot of topics covering this
https://www.thirdgen.org/forums/tech...ortec-lt4.html
https://www.thirdgen.org/forums/tpi/...-tpi-dyno.html
Old Jul 15, 2012 | 09:51 PM
KrisW's Avatar
Car: 88 V6 'bird/89TBI bird/85 T/A
Engine: 2.8/TBI/TPI
Transmission: V8 T-5/700R4 x2
Axle/Gears: 3.42 open/2.73 open/ 3.27 9 bolt
I agree with the above build, its killer.
On the dyno the vortec heads do better than the Corvette heads. If you get a good deal on used Corvette heads its fine, but I think you're better off with the vortecs.
Old Jul 15, 2012 | 10:10 PM
thirdchance's Avatar
Car: 1991 R7U Z28 1LE
Engine: LB9
Axle/Gears: G92 3.42 Truetrac
Yeah the Vortec engine sounds good but are they only found in trucks with a non-roller cam? Can we just swap in a truck Vortec and change the cam???
Old Jul 15, 2012 | 11:16 PM
evilemokid94's Avatar
Car: 1986 camaro Sports Coupe
Engine: L31 350
Transmission: 89 700R4
Axle/Gears: 3.42 gov lock
who told you that crap? all the vortec truck blocks are roller blocks, they have small cams and iron heads but are roller blocks with vortec heads
Old Jul 16, 2012 | 05:45 AM
evo-offer's Avatar
btw, is the vortec heads only in iron? or are they in aluminum to?
Old Jul 16, 2012 | 09:38 AM
Engine: L31 350
dont quote me but i believe all stock vortecs are iron, there are some aftermarkets that are aluminum though
Old Jul 16, 2012 | 09:40 AM
cuisinartvette's Avatar
Car: 67 ******mobile
Engine: 385 Solid roller
Axle/Gears: 4.11
EQ I hear makes some Vortecs that outdo the GMs flow wise and are real reasonable.
MustangBeater20
Oct 29, 2022 09:20 PM
bamaboy0323
Aug 15, 2015 07:20 AM
wruiz
Aug 13, 2015 09:07 PM
gta power
Aug 13, 2015 06:15 AM
Sanjay
Aug 12, 2015 03:41 PM
