Does a 91’ TPI 5.7L motor have a 4-bolt main?
Old Jan 17, 2022 | 08:02 AM
Swinnen25's Avatar
Car: 1991 Camaro Z28
Engine: 5.7L L98
Transmission: 700R4 automatic transmission
Axle/Gears: 7.625 GM 10 bolt, 3.42 gears
I’m looking at building my 91’ Z28 into a badass drag strip car and have some wild ideas. But I’m wondering if the 350 I have has 2-bolt or 4-bolt mains? Mostly because I’m curious if the stock block is worth upgrading or if I should save up and invest in an aftermarket block. I want to keep this as low budget as possible and won’t be pushing past 550hp within the next year or maybe more. My current idea is boring it to a 383 and dropping a good Stroker crank, and forged rotating assembly(pistons, rods etc) and then progressively upgrading heads, intake and camshaft to boost power levels as I gain experience on the strip. My main question that needs answering is the 2-bolt/4-bolt question. Any other advice or opinions are welcomed
Old Jan 17, 2022 | 12:30 PM
Komet's Avatar
Car: 1989 IROC-Z
Engine: L98 350 TPI
Re: Does a 91’ TPI 5.7L motor have a 4-bolt main?
It's probably a 2 bolt. Don't worry, your mains aren't going to twist out of the block. If the engine doesn't need to be torn down, I'd start with the heads, intake and camshaft until you're ready for a power adder. Then, I would go forged bottom end.
Old Jan 18, 2022 | 10:22 PM
Mikos_89's Avatar
Car: '89 GTA, '15 Camaro LS 6sp.
Engine: L98, LFX.
Transmission: 4L60, AY6.
Axle/Gears: 3.27's.
2 bolt main.
Old Jan 19, 2022 | 01:21 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Originally Posted by Swinnen25
I’m looking at building my 91’ Z28 into a badass drag strip car ,if I should save up and invest in an aftermarket block. I want to keep this as low budget as possible and won’t be pushing past 550hp within the next year or maybe more. My current idea is boring it to a 383 and dropping a good Stroker crank, then progressively upgrading heads, intake and camshaft to boost power levels .
Much as we all love our SBC , in this day and age you really can't go past a LS swap for easy , cheap Hp.
Read the stickies here
https://www.thirdgen.org/forums/ltx-lsx/
Write down the final parts cost for your proposed 383 build vs it's hoped for Hp and compare that with a LS engine cost vs Hp.
dark_daku89
Dec 15, 2006 07:31 PM
bnoble
Nov 7, 2006 11:14 AM
IraSummers
Sep 14, 2005 12:26 PM
Fbody fan 35yrs
Nov 9, 2002 05:52 PM
PhatDaddyDave
Jan 5, 2001 08:58 PM
