Delphi injectors
Old Feb 22, 2022 | 06:32 AM
KR81's Avatar
Delphi injectors
Hi guys, keen to hear from anyone who has purchased the delphi stock replacement injectors from southbay, I have a set for my 305 from them and ran into fitment issues as they're substantially shorter than the stock ones, I've followed Frank's install instructions, installing into the manifold first then the rail but due to what I'm assuming is their shorter size, they leak from the rail. The rail is bolted back in place as far down as possible, the only thing I could think of is shaving some height of the manifold mounts which I don't really want to do. Installing them into the rail first as you would with the stock ones results in the bottom of the injector not going far enough into the manifold port. See pics..
Frank has offered me a full refund if they don't work for me but before I take him up on it I just want to hear if others have run into this issue ?
Old Feb 22, 2022 | 03:00 PM
blacksunshine'91's Avatar
Transmission: Pro-built 700R4
Re: Delphi injectors
I think you misread his instructions. You are supposed to install them into the fuel rail first, then seat them into the manifold. Those instructions are on Southbay's website. Keep in mind that the fuel rail is pressurized, the manifold side is not.
Old Feb 22, 2022 | 04:36 PM
aliceempire's Avatar
Transmission: T-5, TH350, T-5
From oring to oring they don't look any shorter
Old Feb 24, 2022 | 01:02 AM
Eightyninef's Avatar
I have a set going into my car now. Very slowly...
Old Feb 24, 2022 | 02:57 PM
TransamGTA350's Avatar
Car: '89 GTA
Engine: ZZ6TPI
The Delphi injectors need to be installed into the rail first and use the stock clips, otherwise they will slide down and leak fuel. As long as the lower O-ring is sitting in the machined bore of the injector boss in the intake manifold, it will be fine.
Old Feb 24, 2022 | 03:38 PM
Komet's Avatar
Car: 1989 IROC-Z
Engine: L98 350 TPI
I did mine into the rails first with clips, and didn't have leak issues. I also made sure the rail was brand-new clean, and wiped just a little fresh motor oil over each seal before they went in.
neilcase
Apr 7, 2021 11:08 PM
landofoz1978
Mar 22, 2011 03:30 AM
kowboy59
Jul 12, 2007 03:35 PM
MiTHRiL
Dec 31, 2006 01:50 PM
