who has the fastest TPI car here?
Old Jul 15, 2007 | 02:12 AM
Jproz1167's Avatar
Car: 1982 Trans Am & 1982 Corvette
Engine: L-98 with LO-3 induction. 350 CFI
Transmission: 5 speed and vette has 700r4
Axle/Gears: 373's in T/A .. vette unknown
As the subjectline says
Old Jul 15, 2007 | 11:05 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Re: who has the fastest TPI car here?
well n/a i think its in the high 11's or so.
blown its probly near 10's. i remember one guy shooting for 10's on stock L98 with twin turbos
i also remember one turbo 305 TPI car doing high 9's
Old Jul 15, 2007 | 11:44 AM
Brisk's Avatar
Car: '88 IROC-Z / '91 Z28 / '91 GTA
Engine: LT4 Hot Cam 305 / L98 355 / MR 383
Transmission: 5-spd / 700R4 / 700R4
Axle/Gears: 3:45 / 3:23 / 3:23
"turbo 305 TPI car doing high 9's"
wow.. thats quick
Old Jul 15, 2007 | 11:55 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
it was in pump gas drags as a honorable mention since it didnt have a cage lol
Old Jul 15, 2007 | 04:50 PM
1MeanZ's Avatar
Car: 86 IROC
Engine: 383
Transmission: TKO 600
Axle/Gears: 3.54 Dana 44 IRS
its Preston Smith's car. It is a de-stroked engine with a 4" bore that just happens to equal 305.
for fastest TPI cars, its not me but I went 12.48@113.67 with a 2.0 60ft and my old lean tune. It might go low 12s now that it is tuned. I think the fastest NA "tpi" cars are in the mid high 11s.
Old Jul 15, 2007 | 04:59 PM
Street Lethal's Avatar
Car: 1990 Trans Am GTA
Engine: Turbo 305 w/MS2
I believe Traxion's naturally aspirated L98 went mid 11's once he installed that Joe Overton camshaft....
Old Jul 15, 2007 | 05:09 PM
Jproz1167's Avatar
Are these stock TPI systems or aftermarket?
Old Jul 15, 2007 | 05:31 PM
^ Ahhh, that would leave Traxion out then, as he was running a miniram at the time. Although it still would be considered "TPI", I didn't realize we were referring to the stock TPI system....
Old Jul 16, 2007 | 06:48 AM
D's89IROCZ's Avatar
Car: 1989 IROC-Z
Engine: 5.7L EFI LTR setup
Transmission: T-5 World Class
no it wouldn't ... TPI is nothing liek a mini ram ... minram doesn;t have TUNED runners ... so thats out .
SO ... fastest tpi ... not superram ...stealthram .. not minram .. not LT1 intake ... only tpi .
12's is awesome ... that would be one fun *** car in town ..
Old Jul 16, 2007 | 07:08 AM
MattODoom's Avatar
Car: '88 G T/A
Axle/Gears: 3.27 9 Bolt
Sure it does... they're just tuned for a much different RPM. Every intake is "tuned", since theyre all essentially air ports.
Old Jul 16, 2007 | 07:28 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
Mini ram is not TPI. Try buying parts for a mini ram and calling them TPI parts. You'll get the wrong crap.
TPI should be specified more clearly. Stock TPI? Aftermarket TPI replacement parts that are still LTR?
Old Jul 16, 2007 | 08:17 AM
Originally Posted by Viprklr
Mini ram is not TPI....
I think your a little caught up in the "TPI" acronym itself. Much like the acronym "IROC", they both have much more of a significant meaning than just being implemented by General Motors. Other than the stock TPI systems runner length, which seperates them apart, they both do the same exact thing do they not? They're both port injected systems, and they're both tuned/governed by the ECM....
Old Jul 16, 2007 | 08:26 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
True, but the acronym was given, by GM, to the LTR setup in our cars.
Old Jul 16, 2007 | 11:36 AM
shocker89bird's Avatar
Car: 89 ws6
Engine: 355 afr195, hsr,gmpp cam, hs rr,
Transmission: t-5
Axle/Gears: 3.08
Well the person who started the thread did not specify wheather it had to be stock style tpi intake or aftermarket. And he did not specify quickest car such as in the quarter mile or fastest car like top speed.
Old Jul 16, 2007 | 01:02 PM
^ He also didn't specify if it had to be a 3rd gen....
Old Jul 16, 2007 | 01:29 PM
Thirdgen89GTA's Avatar
Car: 1989 Trans Am GTA
Transmission: M28 T56
For sake of thirdgen.org then, limit it to a LTR style setup that uses factory replacement parts, base/runner/plenum and you'll have your "fastest TPI." Even magazines are referring to the L98, and LB9 when they write TPI.
I suppose you can include a First Injection setup, but I haven't seen any times with one on a car, there is an article floating around here on the forums though.
Say TPI in an car discussion and EVERYONE is going to think of GM's system. Not the concept of Tuned Port Injection.
Old Jul 16, 2007 | 02:04 PM
Car: 89 ws6
Transmission: t-5
Axle/Gears: 3.08
Well lets say that for some odd reason you decide to change out the restrict stock intake to something that breathes and decide to pop your hood somewhere at a car show. When asked what kind of engine it was what would you say(other than the discplacement)? Not that many people outside of third gens are familiar with the holley stealthram or super ram so it is easiest to say that it is a tpi motor with a different intake.
Old Jul 17, 2007 | 07:37 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
The intake is what makes it a TPI engine.
Here we are debating what the def of a TPI is when no one has even answered the question.
I know my time isn't the fastest but before my build, my best time, bone stock was 14.3 @ 96. I have no new numbers as of yet.
Old Jul 17, 2007 | 02:44 PM
Car: 89 ws6
Transmission: t-5
Axle/Gears: 3.08
Well not here to argue and i understand your point. Usually the guys who havedecided to stick with the inferior stock style design consider it the only tur tpi design even though all electronically controlled engines have tuned runners. Gm just used the name and it was associated with the motor from that point on.
The best I did with the stock TPI intake and just a small cam and exhaust in the qurter mile was a 14.2 at 103.9. The fastest top speed was over 155(uncertain my freinds speedo was past 150 and I was pulling slowly from him). Also calculated through rpm and gear ratio. Worked out to abotu there. Good ole open flat areas of Texas.
Old Jul 20, 2007 | 09:49 AM
91-RS-B4C-fake?'s Avatar
Car: 1991 Camaro B4C
Engine: L98 350 cid (5.7L) TPI v8
Transmission: 700 R4 auto trans
Axle/Gears: 10 bolt w/girdle & 3.42 MotiveGears
Mine is not the fastest.
13.528 @ 99.95
Stock factory TPI
+ TES & exhaust
+ free mods
+ minor bolt on's
+ 3.42 (replaced the factory 3.23)
You can find better times than mine if you search
here hard enough.
You can read about my B4C here for the condensed version
http://www.dragtimes.com/Chevrolet-C...slip-5874.html
Or here for the long drawn out version
http://www.cardomain.com/ride/2175519
Old Jul 20, 2007 | 09:56 AM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Tim Burgess - 'nuff said.
Old Jul 20, 2007 | 10:40 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
13.528 @ 99.95
Stock factory TPI
+ TES & exhaust
+ free mods
+ minor bolt on's
here hard enough.
thats one of the faster mild bolt on cars i've seen with stock TPI!! just abit quicker than my record of 13.63 at 97mph.
well the fastest stock ecm "TPI" motor i know of was 87 TA's 406 miniram that ran off the 730 ecm i believe. ran 10.8's at 126 N/A and 10.07 i believe at 133 with a 150 shot.
Old Jul 20, 2007 | 11:03 AM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
I went 12.6@106 with my my old TPI setup. 1.7 60' TONS of tq but no upper power.
Old Jul 20, 2007 | 01:09 PM
jack harrison's Avatar
Car: 1987 pontiac trans-am
Engine: 350 tpi
Axle/Gears: 3;73 with eaton lsd
ive ran an 11.7 @ 118 mph, its a 87 T/A with a 350 tpi, slp runners, and loads of other stuff including 150 shot. that was with the stock fuel pump, it has a welbro now, pulls MUCH hader, havent tried it with gas yet and havent run it at the track. i have NEVER seen a tpi yet thats as quick here in the uk, so i may be the quickest? id love to hear from anyone else in england if they are quicker.
Old Jul 20, 2007 | 11:47 PM
1991CamaroRslow's Avatar
Car: 1991 L03 700r4 RS
Engine: 1987 WS6 Trans AM Lb2
Transmission: Th350 red neck Performance 3k stall
Axle/Gears: 95 Mustang 8.8 built with 3.73s
13.522 at 97.57mph This is on all stock long block parts aside from LS1 injectors. All I did was porting to the stock base and plenum (along with hammering out the mandatory dents in the runners), Hedman long tubes and duals, ported air box and de screened maf. It's backed by a TH350 with a 3000rpm stall, and 3.27 gears. I'm pretty sure someone has beat me NA on stock long block TPI with a fully stock TPI setup on top but I'm not 100% sure. Unfortunatly this may be the best ever this engine gets to run, I lightened up the car pretty well but I have a Stealth Ram now and I'm not so sure I'm willing to keep the TPI on to see if I can outdo the old time.
Old Jul 21, 2007 | 12:09 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
13.52 at 97 is one of the best times for the power/mph that i've ever seen. very good running car there.
but nah dont keep the TPI. i was the same way as you at one time.. i wanted to see how far i could take the stock L98 with just exhaust. i figured i could get 13.4's if i did some more mods to suspension, did some drag wheels, better gears, and maybe some weight reduction but nothing major. then some tuning. I'd need cold weather, and great track prep but i think it could be done. Just thought it was a waste of time and bought a stealth ram.... i am so happy i did. really made a difference. the top end is soo nice now. definately swap on the stealth ram.
Old Jul 21, 2007 | 09:24 AM
Orr89RocZ, do you ever come over to Englishtown, New Jersey to run? I'd like to see that thing hustle down the track one day....
Old Jul 21, 2007 | 09:44 AM
Sprayed92's Avatar
Car: 92 Formula
Engine: 383 248/256 cam
Transmission: 700r4 3500 stall
Axle/Gears: 9" 3.89 gears detroit locker
Well orr one of the reasons 1991camaro's car ran so well is because of the th350 in the car they have a much better split bewteen the gears if you were to put one in your car it would pick up almost half a second in the 1/4. Seriously we did it to a buddy's car it went 13.5 with a 700r4 with a 2800 stall then we put in a th350 with the same size stall 2800 different converter cause they don't bolt up and with no other changes it went 13.0.The only problem with that swap is you lose od but for a more dedicated strip car it was perfect.
Old Jul 21, 2007 | 11:00 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
i figured the gear spread was a big factor. the 1-2 shift drops but the 2-3 really drops too and kills top end. but i need overdrive, my car is a daily driver in the summer, untill i get my own beater car, hopefully a civic 5 speed with some nitrous lol
never been there, but you know what, i may actually take a trip sometime. i'm up for it for sure! we'll see how it goes. i got a buddy that wants to go racing at other tracks since we dont like ours too much. He's got a bolt on 95 Z28, runs as fast as my car does but he's on street tires haha. those LT1's are strong but i'll talk to him to see if he's down for a run sometime out there. my car aint anything special, i just have fun with it
Old Jul 21, 2007 | 11:42 AM
^ You'll love it over here. I've been saying this for the longest time, a lot of us need to meet up at the track. Was trying to get Dimented, TomP and a few others to come down awhile back. Think it would be awesome to finally start putting some faces to those UserID's. It would be very healthy for this forum if we started posting TPI member results, collectively, on video. Although the crate recently got here, my Formula is still sporting it's original LB9. I'd honestly love to take it down the track w/some of you guys running your L98's. Just make DAMN sure you beat me by at least a full second though..... :P
-Rob
Old Jul 21, 2007 | 11:57 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
lol i hear englishtown is a fast track. just maybe this fall or so i can come down. I'll try to bring down my buddies with their LS1 cars and maybe a few LT1's. they'll whoop up on me and probly alot of us but no worries, its all good fun lol. Maybe 87 TA will come down with his miniram 406 motor in his new car, the 94 formula
Old Jul 21, 2007 | 01:15 PM
I started a thread on here a long while back about what I would gain from doing a TH350 swap and Pro Built said "not much". I went through with the swap anyways, better stall and better tires and my track times went down by 1 tenth. I went from a 14.0 to a 13.9 going to a 3000rpm stall and a stickier set of tires; I also lost a bit of trap speed but that's to be expected with a looser stall and softer sidewall tires. The very night I ran the 13.9 I pulled the screens out of the MAF just to see if it would help and the car went a 13.8. My biggest gain came from massaging the air box with a heat gun and porting the base. This is what put me at 13.5. I have alot of this documented in my threads if you do a search. I'de be interested to see someone else do a comparison of just doing what I did with the base, air box, and exhaust. I feel that's where the biggest gains are to be had with these cars.
Old Apr 19, 2009 | 03:17 AM
gearhead0384's Avatar
Car: 1989 Camaro IROC-Z
Engine: L98 350 TPI
Transmission: Built TH-700 R4 (Vilgilante 2800)
Axle/Gears: 9 bolt w/ PBR's
Good to hear.
I take it my 13.5 at 97 mph, with long tubes and a converter is not to shabby then.
Kevin
Old Apr 19, 2009 | 07:21 AM
88fastgta's Avatar
Car: 1988 Flame Red Trans am GTA
Engine: Forged 355 4 Bolt, FIRST TPI
Axle/Gears: ls1 torsen 3.42 gear
im very curious to see what i will do at the track with my tpi motor this summer... im trying to get the most i can out of gm's ltr design and so far im pretty sure i maxed out the edelbrock/slp combo as far a porting wise...... should be a easy 12 second car.... i've done basically every bolt on possible with my gta, newly blueprinted 355 forged block...... should be very interesting...
Old Apr 19, 2009 | 07:27 AM
88fastgta's Avatar
i know i will have a very fun daily driver thats for sure....
Old Apr 19, 2009 | 02:48 PM
89IrocZ350TPI's Avatar
Car: ws6
Engine: ls1
Transmission: m6
Wow you guys are quick. I am lucky to hit 13.2's.
Old Apr 20, 2009 | 02:45 PM
govenorcamaro's Avatar
heres a link to a video of my cars the red one is going through an huge transformation right now should be an mid 12 second car in about a month without nitrous stay tuned. this what it ran last year on a cold day well about 60 degress it could do 13.59 at 99.79 any other day is 13.7 at 99.07 this had tes headers, pulleys, modified chip by someone,anf full 3 inch exhaust 40 series single in, single out......
http://videos.streetfire.net/video/9...-gt_194535.htm
Old Nov 17, 2013 | 09:51 PM
NufNuffZ28's Avatar
Car: 1987 Iroc
Engine: 357 Single plane and a Ysi vortech
Axle/Gears: 3.50 9"
I just ran a 10.5@134 with a STOCK PORTED TPI base
Old Feb 24, 2022 | 08:17 PM
91GT347's Avatar
Yes this threads old, dead, buried, rotted and reincarnated. Lol
I ran a 12.99 a long *** time ago in a full weight 87 GTA. TFS heads, SCT chip, Accel lower intake and a K&N filter. Everything else was stock.Sorry for the revival. It was my first (and last)12 second pass. Lol That was quick in the early/mid 90s.
Old Feb 25, 2022 | 08:07 AM
Johnny Gun's Avatar
Car: '88 GTA
Engine: 355 SBC, AFR 195 heads, Stealth Ram
Yeah... not me.
Wade787b
Sep 29, 2015 01:15 PM
Brcharrelson
Aug 26, 2015 07:47 PM
NBrehm
Aug 25, 2015 11:49 PM
ZZ42Fast
Aug 10, 2015 08:20 PM
