New fuel injectors leaking, any ideas?
Old Mar 16, 2011 | 11:54 PM
landofoz1978's Avatar
Car: 1991 Z-28
I just got done putting in a set of Bosch III fuel injectors that I bought from SouthBay. Problem is I cannot get them to seal up good. I have taken them apart and reinstalled them several times but everytime same result leaks all over the manifold. Tried it once with the new o rings on the manifold side of the injector and once with the o rings from the old injectors and same thing. It seems that they are leaking from the manifold side. The O rings that came on the injectors are not rounded on the sides like the factory ones. Wondering if I should get a new set of o rings from the parts store and try that, that is about the only thing I can think of to do. Any ideas would be appreciated!!!!
Old Mar 17, 2011 | 12:58 AM
Guest
Guest
Posts: n/a
Re: New fuel injectors leaking, any ideas?
What exactly is leaking?
Old Mar 17, 2011 | 01:00 AM
Car: 1991 Z-28
Fuel is leaking up around the bottom of the injector where it goes into the manifold.
Old Mar 17, 2011 | 08:53 PM
southbay08's Avatar
First of all, if you are having a problem with our injectors why don't you just call us so we can help you??? The orings that are on the bottom of the injector do not look like the factory orings because we have them custom made for proper fitment into the manifold with our adapter. Are all of the injectors leaking from the manifold? Did you install them into the fuel rail first or the manifold? Please give us a call tomorrow....
516-492-6504
Old Mar 21, 2011 | 05:32 PM
randyz91's Avatar
Car: 1991 z28
Engine: 5.7 tpi
Transmission: th700r4
From my own experience with South Bay I would give thim a call. This is what they do. This is their product. They will not be happy until their customer is happy. Otherwise they would not be able to stay in business, give them a call. No, I am not a paid endorser,but, a satisfied customer. Good luck! Randy
Old Mar 21, 2011 | 07:03 PM
southbay08's Avatar
Thanks Randy, much appreciated..
Hey landofoz1978, haven't heard from you yet. Have you figured out the problem????
Old Mar 21, 2011 | 07:19 PM
old z mzn's Avatar
Car: 1992 z-28
Engine: 383 stealthram
Transmission: auto
Axle/Gears: 4.10
mine installed with no problem
Old Mar 22, 2011 | 03:30 AM
unprdictable1's Avatar
My Southbay injectors installed with no problem. Just a note for ya, make sure that when you install the injectors that you lubricate the "O" rings prior to putting them into the fuel rail, as well as the intake manifold. not using lubrication during the install can cause the "O" rings not to seat correctly. Hope this helps.......
bryan623
Mar 22, 2021 06:43 PM
jklein337
Sep 19, 2018 06:23 PM
kyleb24
Aug 15, 2015 08:24 AM
Firechicken86
Aug 12, 2015 10:07 PM
Kaweh
Aug 9, 2015 02:54 PM
