'89 formula TPI harness and ECM in an '86 Z28
Old Mar 3, 2022 | 02:08 PM
Better Daze's Avatar
Hi, new here. I have an 86 Z28 with a 350 that was carb swapped, orignally 305 TPI. I'd like to go back to TPI. I have an 89 formula 350 parts car, can I use the system from that car in mine? I know it's a VATs system. How complicated would the swap be if it will even work?
Old Mar 3, 2022 | 02:11 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: revert back to TPI
What will the harness be from ?
Old Mar 3, 2022 | 02:13 PM
None of the original engine harness remains, so it would be from the 89.
Old Mar 3, 2022 | 03:01 PM
Engine: Lb9
Transmission: M20
Vats can be deleted from the tune easily.
the ccp battery leads are on the opposite side of the car. Might research c207 and c100 difference or get a 86-87 camaro harness.
IssaIroc
Aug 20, 2018 03:22 PM
goleafsgo143
Feb 16, 2009 09:52 AM
2low4fathoes
Sep 14, 2003 04:58 PM
texasgt
Feb 17, 2002 12:55 AM
