85 305 TPI to 89 350 TPI
Car: 2003 HD 1500 4 door Chevy
Engine: 6.0
Transmission: 460LE
I have an 305TPI 85 IROC. I got a great deal on a 89 TPI 350 with tranny. Problem is that I have everything (including computer) but the harness. Is there a way to rig my current harness ? The new ones from Painless are not made for cars with AC. I am going to get this combo so I need a solution. If I have to carb it I will, However I would rather keep it TPI. I have the computer so I have no idea if I can just swap computers.
I could use some real help
Check out this tech article: http://www.eecis.udel.edu/~davis/z28/ecm_swap/
It tells you how to convert your '85 harness to work with a 86-89 computer. It tells you step by step what to do and how to do it. Check it out and go for it.
Transmission: 4L80E/4L80E
Certainly is the right move, changing to the later ECM type.
You may also be able to get an unhacked '89 TPI harness from a bone yard. Would be worth a try.
Sanjay
Aug 12, 2015 03:41 PM
