Intermittent CEL ?
Old Jul 25, 2022 | 10:49 PM
c-137's Avatar
Car: 85 t/a
Engine: 5.0 tpi
Intermittent CEL ?
Hope this is the correct place to post.. 85 TA 5.0 TPI LB9.. check engine light comes on once in a while and drives rough while its on but next time i start it the light won't come on and it'll drive fine. When the light's not on i can't get any codes with the paper clip.. only 12 repeating.. how do i find out what's causing the light to occasionally come on?
Old Jul 26, 2022 | 08:36 AM
92RS-HeritageEd's Avatar
Car: 92 RS / 90 IROC-Z
Engine: 305 / 350
Axle/Gears: Non-Posi / Posi - Both GU2 - 2.73
Re: Intermittent CEL ?
Hello, If I'm not mistaken... it has to be operating under the conditions that set the code for more than 20 or 30 seconds or something before it's stored to ECM memory. Shut off & restart before code is stored & boom all you're getting is Code 12. Good luck!
Old Jul 26, 2022 | 07:10 PM
1989karr's Avatar
Engine: 3.4 / 5.0
Transmission: 700-R4
Axle/Gears: 3.42 / 3.42
Ive had codes stored in my 67 for things that arised for less tan 30 seconds. Im not sure if the 85 is different though.
Did you leave the clip in and let it flash past the cde 12? it will always flash code 12 first before the next code
Old Jul 26, 2022 | 09:44 PM
c-137's Avatar
Car: 85 t/a
Engine: 5.0 tpi
yes it flashed 12 three times.. then 3 more times. No other codes. I still can't get the light to come back on.
Old Jul 27, 2022 | 12:24 PM
1989karr's Avatar
Engine: 3.4 / 5.0
It could be like 92 RS said where wither the older ecms need so many seconds of the actual problem, or certain problems will require this,
Is the light flashing or steady when on?
If anything, Id disconnect the battery to reset everything and see if the problem itself comes back.
jimmomo
Oct 20, 2021 05:29 PM
AfdahlBo
Jul 22, 2020 06:54 PM
JAYCREDIT
Feb 7, 2012 09:05 AM
warrior_91
Oct 26, 2010 11:47 AM
gchu
Mar 5, 2004 10:18 PM
