LB9 Ticking noise. Normal? Injectors?
Car: 1989 Camaro IROC-Z Convertible
Engine: 5.0
Transmission: 5 Speed
Axle/Gears: 3.08
Hi all.
just wondering if you can have a listen and see if my engine sounds normal at idle. Feels like the ticking is quite loud.
im assuming this is the noise from the injectors. These are also Bosch injectors.
Thank you for listening and commenting.
Transmission: T-5, TH350, T-5
Re: LB9 Ticking noise. Normal? Injectors?
Use a stethoscope (or a rubber hose on the cheap) to see where the noise is strongest. I'd be inclined to agree with injectors but I can't put my ears to anything through a video
Engine: 5.0
Axle/Gears: 3.08
thanks for your comment.
Car: '90 Formula '88 GTA
Engine: 305 TPI 350 TPI
Transmission: T5 700R4
Axle/Gears: 3.42 10 Bolt 3.27 9 bolt
I put new Bosch III's from SBFI in my formula they are very clicky - they sound SIMILAR to that... however yours appear to be more of the stock type.... second the stethoscope suggestion, or a long screwdriver (careful around belts/fans obviously),.. almost sounds like a manifold leak
Car: 1989 IROC-Z
Engine: L98 350 TPI
My injectors do tick somewhat like that, doesn't seem like mine are quite as loud but in person is different than what a microphone is picking up.
Is it running weird? Can you still hear it with the hood closed? You could try running with the belt off for a few seconds to verify it isn't coming from the accessory drive. Also a smoke test would be ideal for potential vacuum leaks.
Engine: 5.0
Axle/Gears: 3.08
