what is this bolt for on the intake?
Old Jan 20, 2002 | 02:15 PM
monte-ss's Avatar
Car: 87 Monte Carlo SS
Engine: 89 IROC 350 TPI
Transmission: 700R4 rebuilt w/TCI kit
Axle/Gears: 9" from 57 ranchero unsure gears.
Hey guys Im not sure how to explain it, but on my TPI system on the pas side upper plenuom there is a bolt that bolts the runners to the plenum, its not the standard torx boltlike the rest its a 10 mm(wrench) bolt with a spear(sorta) coming out of it and is about an inch or so long. Im just wondering if its supposed to be used to mount something? otherwise it is used as a standard bolt.
thanks
Jack
Old Jan 20, 2002 | 02:58 PM
TC602's Avatar
Car: 86 IROC
Engine: ZZ4
Transmission: T5 WC
Yes it is for mounting you throttle cables. On my car it is on the driverside. The cruise cable and throttle cable mount there, it keeps them from laying on the plenum. I dont know why yours is on the passenger side unless someone has had the plenum of and did not put it back on the proper side. On the cables there is a clip that secures the cables and then slide over the spear.
rezinn's Avatar
I believe it originally held the throttle cables, but obviously it isn't now. You can replace it with a regular bolt if you feel like it.
Old Jan 20, 2002 | 02:59 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
There's plastic clip that holds the cables (similar to plug wire seperators..) that slips onto that spear.
Old Jan 21, 2002 | 12:49 AM
monte-ss's Avatar
I figured it didnt matter much it has always been on the wrong side to hold the cables since I got it, I was just curious as to what it was supposed to be and figured it had to hold something.
thanks guys
Jack
Terrell351
Jun 13, 2021 01:13 PM
deracer
Apr 11, 2016 12:04 AM
LT1Formula
20
Nov 14, 2015 12:02 AM
theurge
Aug 21, 2015 12:46 PM
