350 TPI build advice/tips/thoughts
Old Nov 12, 2022 | 12:29 PM
Scamo-2.8's Avatar
Car: 1989 Camaro RS
Engine: 1990 - 5.7
Transmission: Tremec 3550
Axle/Gears: 9 Bolt - 3:45
Hi all,
I'm looking at making my 1990 TPI 350 the best it can be with bolt on parts of sorts. I'm thinking about pulling the trigger on a set AFR 195 Enforcer heads (1001), but they're a few bucks and thought you all might have a few things to add/say.
I'm not really a track/strip guy but enjoy the street-able fun of the TPI and thought it could use a little something to make the HP a little more respectable. I've been on here for years reading and I understand the stock heads are the downfall after you upgrade the TPI, which I have done. Here's my current combo:
Stock 1990 350 internals,
AS&M runners,
Accel high flow lower base,
Holly 52mm throttle body,
Port matched plenum,
Hooker shorty headers,
1985 BW T5 - (babied for anti explosion purposes),
1989 9 Bolt 3:45 gears,
Before anyone mentions it, I have upgraded most of my suspension with UMI/Spohn/Koni parts, and brakes through bigbrakeupgrade.com
Waiting in the wings to be installed:
ZZ9 cam - Oldie but still a goodie?
EBL P4 - No tuners in my area, time to learn,
TKO 500 - oldie but will take more torque then my current BW T5,
ARP head bolts,
I really could use some advice on: Rockers and rocker ratio, thoughts on stock bottom end, ZZ9 cam - anything better (keeping it street-able), injector size, and anything and everything else I've forgotten.
I'd like to stay TPI, LS stuff is awesome and great - I should probably go that way, but I like the stock look. It my first car, I bought her back in 2000 and every year or two I like to upgrade/modernize some aspect of it. This winter it's the engines turn.
Thanks for all your time, comments, advice, experience, and help.
- Charlie
TPiroc89
Jan 15, 2022 12:07 PM
PhoenixFirebird
Sep 2, 2012 08:23 PM
carfreakpeewee
May 31, 2011 12:47 AM
cruzplcs
Oct 20, 2010 09:19 AM
mat89RS
May 15, 2002 01:37 PM
