Engine suddenly died
Old Mar 23, 2023 | 05:39 PM
Jordan Ruddick's Avatar
Hello I have a 350 tpi in my 88 and I’ve been having misfire issues I’ve change a lot of parts involved with the ignition and I drove around today after the parts were done and it ran fine for about a hour then as I was on my homes street only going 15 the engine lost power wouldn’t respond when I tried to give it gas it was knocking but the oil pressure wasn’t bad or any of the gauges the only part I haven’t changed yet is the distributor itself and now the car won’t start at all but before I turned it off I listened to the idle and there were no knocks or any suspicious sounds has anyone had this issue? Could my distributor have just died or could I have a spun bearing?
Old Mar 23, 2023 | 07:42 PM
tajefe's Avatar
Re: Engine suddenly died
Would think it could still run if you spun a bearing or would hear it usually. Got any spark now?
Old Mar 23, 2023 | 07:51 PM
I’m not sure I haven’t done any testing yet but the engine turns fine just won’t start
Old Mar 24, 2023 | 07:22 AM
ironwill's Avatar
Car: 1986 IROC Z
Engine: 5.0 TPI
Axle/Gears: 3.23 Posi
At this point, the problem could be anything. Start with the basics---fuel pressure, spark at the plugs, and injector pulse at the injectors. The results of those tests will provide you with some direction in which to further troubleshoot.
A spun bearing wouldn't keep the engine from starting as long as the crankshaft still spins.
Old Mar 24, 2023 | 07:26 AM
SbFormula's Avatar
Car: '18 Chev Camaro SS 1LE
Engine: LT1 6.2L
Axle/Gears: 3.91
"Ask questions, do testing later" mantra
IndyFirechicken
Aug 13, 2018 06:10 PM
CamaroHawke
Mar 26, 2010 03:01 PM
GearHeadHetch
Nov 12, 2003 05:14 PM
Justin91RS305
Mar 5, 2002 10:23 PM
