runs good, then stalls
Old Jul 8, 2023 | 07:04 PM
Justin_p's Avatar
Hey there!
I own an 86' irocz z28 (LB9) and I've been having issues with it the last while. If it sits for a while it'll run amazing for about 10-15 mins then stalls out and won't start up after. It'll start to run really rich after. I'm a little lost on whats happening. I've replaced the 02 sensor, MAF, IAC, pick-up coil, fuel pressure regulator and put in new spark plugs. I might be missing somethings. Can anyone give me some advice on the issue?
Thanks!
Old Jul 8, 2023 | 07:30 PM
Reddragon88gta's Avatar
Engine: 5.7 L98
Re: runs good, then stalls
Without live data/scan tool this will be tough to diagnose without knowing what the computer is seeing... Any check engine light or codes? Have you checked the injectors by ohm readings them warm and cold? Have you tested the Ignition Control Module? Just throwing a few ideas out there.
Old Jul 8, 2023 | 07:37 PM
Justin_p's Avatar
When I scanned it, it was only coming up with code 34. I've checked the injectors and they were reading correct (I can't remember of the top of my head but they matched the book) I also put in a new ICM when I did the pick-up coil.
Old Jul 8, 2023 | 08:00 PM
Engine: 5.7 L98
Do you have a scanner that can get live data? Check your wiring for the MAF and its relays, these cars are also sensitive to aftermarket MAFs and sometimes a cleaning with MAF cleaner helps. Also have you checked the Throttle Position Sensor to be sure it is set at proper voltage (.54v) and voltage readings are smooth and not erratic when opening and closing the throttle? Any fuel pressure readings? I wonder if you have some leaky injectors?
Old Jul 8, 2023 | 08:10 PM
Justin_p's Avatar
I had a friend with the Obd1 scan tool hook up and TSP seemed to be in good order (we used the scanner months ago and everything was to the book) I am reading fuel pressure, I haven't put a gauge on but It does have pressure. If my injector is leaking would there be any signs? I'm a younger guy and I'm learning everything as I go. As per MAF, I see no wire issues and I did get a new MAF to see if it would resolve the issue. Correct me if I'm wrong but I believe code 34 does pop up if it doesn't start. I do have the EGR deleted. Maybe my vacuum is the issue?
Old Jul 8, 2023 | 08:41 PM
Engine: 5.7 L98
If your injectors are leaky fuel pressure would drop down pretty fast, but you will need a gauge to tell, after shutting the engine down, also say you go for a ride and shut it off for a brief time and try to restart and it will not want to start unless you floor the accelerator and once it starts it will have a smoky/gas smell from fuel leaking from the injector/s. I would buy or get a fuel pressure gauge and see what's happening there, that tool is needed with these cars.
If you have a vac leak you will hear a hissing sound and idle will be high or erratic. You can make a simple smoke tester with a $5 harbor freight fluid exchanger and a cheap cigar, there is a good video on YT that shows you how.
I would hook up the scan tool and see what the data reports when the issue happens, that way you can see what may be causing the issue.
Old Jul 8, 2023 | 08:52 PM
Engine: 5.7 L98
did you use a block off plate when deleting EGR?
Old Jul 8, 2023 | 08:57 PM
Justin_p's Avatar
I did yes. I also closed the vacuum system when doing so, well to my knowledge I did. I've been using this very helpful forum along my journey but with this current issue, I've yet to come across a solid lead.
As per your last message. I will test for a vacuum leak and run a gauge to see what's going on. Using the scanner is hardly an option for me at the moment. Been trying to find one to buy. Will keep the thread up to date for other members.
Old Jul 8, 2023 | 09:32 PM
Engine: 5.7 L98
Keep us posted, a snap on MT2500 aka The Brick is a solid choice and can be found used on ebay etc but be sure to get the right cartridges for your car. I use a BT scan tool from 1320 electronics that has worked great for me and is inexpensive but last I knew he had supply issues but may be worth a look. Actron9690 is also supposed to be a good one too
Old Jul 8, 2023 | 09:45 PM
Engine: 5.7 L98
This may help too from the factory service manual:
Engine: 5.7 L98
Need Help with code 34 - Third Generation F-Body Message Boards
Last edited by Reddragon88gta; Jul 8, 2023 at 09:47 PM. Reason: image wouldn't load
Old Jul 8, 2023 | 09:47 PM
Justin_p's Avatar
Thank you so much! I will look into getting a scan tool and going from there. That 1320 looks very interesting and will do so research. Thanks again for everything, hopefully I'll have an update soon!
Old Jul 10, 2023 | 09:18 AM
alan91z28's Avatar
COTM Editor
Car: 91/89/85/82 Z28s, 88 TA, 88/88 SC
Engine: SBC and LS variations
also one other easy thing to check is since it seems to be once it warms up you are having trouble and you think it is running rich, make sure the temp sender to the ECM is working... if it fails open circuit the ECM will think it is -40 outside and be adding a lot of fuel
Old Aug 16, 2023 | 03:40 PM
Justin_p's Avatar
Hello Everyone,
Been busy with life and got time now to look back into my issue. I started checking wiring and seeing if there was damages in the harness and and came across I assume a ground?(brown and black with white stripe) Not sure trying to look at the wiring diagram but it's difficult for myself to determine what it's for. Anyone able to inform me?
Old Aug 16, 2023 | 04:09 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Ground to the back of the cylinder head. Iirc aldl ground and ecms o2 ground.
Old Aug 16, 2023 | 04:10 PM
alan91z28's Avatar
COTM Editor
yes, that is going to be a problem... those are grounds and it should be bolted to the back of the head
Old Aug 16, 2023 | 04:12 PM
Justin_p's Avatar
Awesome thank you guys! I found it tucked inside a wire loom. Will hook it up and see what happens.
Old Aug 16, 2023 | 04:22 PM
Engine: Lb9
Transmission: M20
Btw does this run any better ? If it has the AUM memcal in the computer I’ve seen that cause all kinds of running issues. Might check it and search some of vaders old posts on that calibration issues.
Old Aug 16, 2023 | 04:27 PM
Justin_p's Avatar
Unfortunately it's still acting up. It'll run perfect then slowly kill itself still. I have videos of it happening not sure if they can be posted still new here. That's why I started going through the wiring thought maybe when it gets warm a wire is loosening up. But I will look into that. I'll have to learn all about that. Still new to this and it slows me down lol
Old Aug 16, 2023 | 04:28 PM
Justin_p's Avatar
Also where would I find out if it has that?
Old Aug 16, 2023 | 04:30 PM
Engine: Lb9
Transmission: M20
Having the o2 ground might really help it actually going into closed loop. Here’s some information about the AUM calibration. Just a thought you might want to see what’s in the ecm.
https://www.thirdgen.org/forums/tpi/...fter-cold.html
Old Aug 16, 2023 | 04:41 PM
Justin_p's Avatar
Okay thank you, it does have an aftermarket e-prom in it. I still have the factory one. That was my next look if I can't find something more noticeable.
Old Aug 16, 2023 | 04:58 PM
Engine: Lb9
Transmission: M20
I think the blue one says any not a bad tune i don’t think. Might be better than a jets.
Old Aug 16, 2023 | 05:15 PM
Justin_p's Avatar
Okay thank you for your knowledge! I remember when I first got the car running it had the stock one in. It ran pretty good, when I put the jets one in, it was like a different car it sounded healthier smoother idle and sounded like it it wanted to lay down 11's 😂
Old Aug 16, 2023 | 09:07 PM
Justin_p's Avatar
So after putting everthing together the issue was still there. I swapped out the proms and the car ran perfectly fine, even made to operating temperatures. Guess the jet prom had issues
antman89iroc
Oct 8, 2013 07:11 AM
Crudsturbo
Jun 25, 2013 03:27 AM
xpsmoto
May 27, 2010 03:33 PM
sscamaroracer87
Sep 10, 2009 02:47 PM
87ColdAirIroc-Z
Oct 29, 2002 11:24 AM
