No crank, no start, Security light on.
Old Nov 14, 2023 | 08:07 AM
chazman's Avatar
Transmission: World Class T-5
Axle/Gears: BW 3.45
1989 IROC, LB9, 5 speed, 11K miles.
I've searched every thread.
No crank, no start, security light on. Can hear fuel pump.
Had PROM burned with VATS delete, no change.
Jumped starter enable relay, will crank but won't start. Replaced starter enable relay with known good part, still no crank.
Got one of those VATS bypass kits, (but for a Corvette, if it matters) at the correct ohms, no difference.
Removed VATS fuse in the convenience center, (security light goes out), no change.
I feel I have gone through enough steps to bypass VATS, but security light still stays on, (with VATS fuse in) and starter enable relay won't work, unless I jump it.
What am I missing? Help!!!
Old Nov 14, 2023 | 09:07 AM
Vader's Avatar
Re: No crank, no start, Security light on.
It does sound like a possible VATS issue. Even though the flag has been turned off in the PROM, the rest of the system needs to function in order to enable cranking and injector pulses. That includes wiring, relays, switches, a module, and the ECM.
Checking the injectors for the presence of the 12V supply and the ground pulses could be revealing. Attempting to start with manually administered fuel or starting fluid could also provide useful information.
Old Nov 14, 2023 | 09:33 AM
chazman's Avatar
Axle/Gears: BW 3.45
Thanks, it has already been suggested to me to check the injectors for power, something I plan on doing. I am almost becoming suspicious of the ECM though. I mean what else can be left? When I have time, I'll try swapping the one from my other '89 and see what happens.
Old Nov 14, 2023 | 09:50 AM
chazman's Avatar
Axle/Gears: BW 3.45
I've watched a number of Youtubes where they quickly and easily defeat VATS by splicing a correct resistor into the wires coming out of the steering column. I'm not in favor of such hackery on my mint car. But I never thought VATS would give me such a fight.
Old Nov 14, 2023 | 10:32 AM
Komet's Avatar
Car: 1989 IROC-Z
Engine: L98 350 TPI
You have to jump the starter enable relay and leave it that way; look at a wiring diragram. You will see that it only exists to give VATS the ability to interrupt the signal. If VATS has been turned off in your tune as well, then you don't need the bypass kit and it doesn't matter what the security light is doing.
As Vader mentioned, the next step is checking the injectors for the presence of the 12V supply and the ground pulses.
Old Nov 14, 2023 | 12:57 PM
chazman's Avatar
Axle/Gears: BW 3.45
What no power to the injectors indicate?
Old Nov 14, 2023 | 01:57 PM
Komet's Avatar
Car: 1989 IROC-Z
Engine: L98 350 TPI
That the problem is upstream of the injectors. You are still in the fact-gathering stage of diagnostics. We need more facts to narrow down the problem.
Are these original injectors? Was it recently running, or hasn't ran in 5+ years? What is the fuel pressure? Does it pop off on starting fluid?
Old Nov 14, 2023 | 02:04 PM
chazman's Avatar
Axle/Gears: BW 3.45
Gotcha! For the record, car ran several days before and ran AWESOME,.Original multecs failed years ago and were replaced with new 19# Bosch's. I will check power to injectors as soon a s I can.
Old Nov 19, 2023 | 02:53 PM
chazman's Avatar
Axle/Gears: BW 3.45
Power is getting to injectors with the key on.
Old Nov 19, 2023 | 03:31 PM
Komet's Avatar
Car: 1989 IROC-Z
Engine: L98 350 TPI
That's good, does the noid light pulse during crank?
Old Nov 19, 2023 | 07:43 PM
chazman's Avatar
Axle/Gears: BW 3.45
I don't know. I didn't crank while checking.
Old Jan 9, 2024 | 11:56 PM
Eightyninef's Avatar
Did you figure it out?
cfirebird90
Jul 23, 2016 10:04 AM
insomniac
Mar 13, 2013 12:29 PM
Steve91Z28 L98
Mar 13, 2013 08:13 AM
robrs25th
Apr 19, 2012 09:53 PM
ltblue89rs
Jul 13, 2010 06:26 PM
