Gaskets for ported runners?
Old Jan 23, 2024 | 02:03 PM
keis's Avatar
I will probably be porting my plenum and runners so what gaskets are people using for ported stock runners and plenum?
-keis
Old Jan 23, 2024 | 02:05 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Gaskets for ported runners?
Mr gasket 146 or tpis has large tube gaskets. If siamese make your own.
stock runners get felpro or mr gasket 145.if you don’t have larger than stock ltr I wouldn’t waste your time.
Old Jan 23, 2024 | 03:38 PM
Tom 400 CFI's Avatar
Engine: LT1, L400
Transmission: ZF6, T5
Axle/Gears: 3.45, 3.31
I used these:
GASKETS FOR BIG/CUSTOM RUNNERS
Old Jan 24, 2024 | 08:19 AM
vinny R's Avatar
Car: 1991 Z28
Axle/Gears: 3:42 Auburn
-keis
if you have stock runners don't waste your time, the walls are too thin.
Old Jan 24, 2024 | 09:00 AM
Vader's Avatar
Vinny is correct - There is little chance of enlarging the stock runners, but the transitions can be improved. About a quarter century ago I port-matched the runners to the plenum and base on mine. The plenum was off so that the injectors could be removed for cleaning. I used Fel-Pro stock design (fiber/metal core) gaskets and carefully trimmed them using a die and punch.
Old Jan 24, 2024 | 12:27 PM
Engine: LT1, L400
Has anyone here on TGO tried the steel ball method, for "porting" the runners? Is it as much of a "joke" as it seems it might be?
Old Jan 24, 2024 | 09:48 PM
BHR's Avatar
BHR
-keis
stock gaskets ported, last time i checked 146 were hard to get and expensive they are also thin paper and prone to tearing
Old Jan 24, 2024 | 09:53 PM
BHR's Avatar
BHR
yes they turn out well I have done 39mm inner diameter
accel cast runners are less than 37mm inner diameter and where documented to flow 240 cfm and believe when extrude honed where 275cfm
Old Jan 24, 2024 | 09:56 PM
Engine: LT1, L400
Thanks! I didn't know if that was a real, viable thing, but interesting to hear that it works.
Old Jan 24, 2024 | 09:59 PM
BHR's Avatar
BHR
source of flow, numbers have been posted all over the net
https://www.thirdgen.org/forums/tpi/...5-runners.html
Old Jan 24, 2024 | 10:00 PM
BHR's Avatar
BHR
I may have to send you another intake I think it can get very close to the last test you did
Old Jan 24, 2024 | 10:04 PM
Engine: LT1, L400
I'm game.
89mulletbird
Apr 13, 2014 12:36 PM
87Iroc5.0
Nov 29, 2012 03:02 PM
gmendoza
Jan 5, 2010 03:06 AM
trueburton
Mar 12, 2005 12:41 PM
d4nk
May 7, 2002 06:22 PM
