88 Camaro 5.7 TPI High Idle and Surging
Old Jan 29, 2024 | 11:50 AM
JuanZ28's Avatar
Car: 1987 Camaro Iroc Z28
Engine: 5.7 TPI
The car is idling high 1500rpm and comes down at about 800 to 1000rpm when warm but surging idle.
Car was always doing the surging and it had a code 36.
Got that taken care of.
After chasing this problem these are things
I've done so far to my car: New Fuel filter, IAC, TPS, FPR, Distributor, cap, rotor, plug wires, spark plugs, MAF, replace gaskets on intake manifold and runners, EGR valve and vacuum lines to make sure that I don't have any vacuum leaks.
After I got all these things done I took the car out for a drive. On take off the car runs good but then it chokes up and on wide open Trottle I can hear the car back firing not sure if it's from the Trottle body or exhaust tail pipe then the car will die.
The car starts up again but not running as it should.
Any tips advice on what could be the problem.
Thanks in advance.
Old Jan 29, 2024 | 10:30 PM
JuanZ28's Avatar
Engine: 5.7 TPI
Re: 88 Camaro 5.7 TPI High Idle and Surging
Thanks in advance.
Old Jan 30, 2024 | 10:14 AM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Why is the aldl in field service mode while timing ?
Old Jan 30, 2024 | 11:45 AM
JuanZ28's Avatar
Engine: 5.7 TPI
Hi I set the timing 1st without the jumper on A&B on the ALDL.
Then I use the jumper on the ALDL, disconnect the IAC pigtail and tried to set idle @ 450 but car dies at around 900rpm.
Old Jan 30, 2024 | 11:52 AM
Engine: Lb9
Transmission: M20
If iac was commanded in and unplugged. the minimum idle speed gets set. If throttle blades are almost closed you have a vacuum leak or iac is incorrect or not moving all the way in.
Old Jan 30, 2024 | 03:58 PM
JuanZ28's Avatar
Engine: 5.7 TPI
IAC was commanded by installing the U conductor to A&B on ALDL, turn the ignition to the On position waited 30 seconds to disconnect the pigtail connection to the IAC.
Started the engine and was backing out the Idle screw to lower the RPM to 450 but couldn't achieve that engine will cut of at 900rpm.
I will recheck for vacuum leaks and watch throttle blades to see if they are fully closed.
Can the new MAF be defective and cause high idle too?
Old Jan 30, 2024 | 04:25 PM
Engine: Lb9
Transmission: M20
The engine stalls at 900 rpm
or is just not going below 900 rpm ?
Old Jan 30, 2024 | 04:56 PM
JuanZ28's Avatar
Engine: 5.7 TPI
It stalls at 900rpm and completely shuts off
Old Feb 2, 2024 | 08:33 AM
JuanZ28's Avatar
Engine: 5.7 TPI
[QUOTE=Tuned Performance;6523191]If iac was commanded in and unplugged. the minimum idle speed gets set. If throttle blades are almost closed you have a vacuum leak or iac is incorrect or not moving all the way in.[/QUOTE
I was unable to find any major vacuum leaks. There's a small leak on the passenger side valve cover where a hose from the throttle body comes into a rubber grommet..
I suspect the IAC valve to be faulty. I removed it when it was cold and the Pintle is in the same position as when the car was hot.
Old Feb 2, 2024 | 07:28 PM
JuanZ28's Avatar
Engine: 5.7 TPI
[QUOTE=JuanZ28;6523447]
I was unable to find any major vacuum leaks. There's a small leak on the passenger side valve cover where a hose from the throttle body goes into a rubber grommet..
I suspect the IAC valve to be faulty. I removed it when it was cold and the Pintle is in the same position as when the car was hot doesn't seem to extend or retract. Voltage meter reads 11dc from light blue/white - wire to light blue/black +
same 11dc from lht grn/wht - to lht grn/blk+.
​I then contacted the pigtail back to the IAC valve and switch on and off the Ignition again no movement from the IAC Pintle.
beastycamaro
Apr 8, 2017 07:32 PM
camaropower88
Mar 14, 2012 09:13 PM
GunGreyForm
Sep 1, 2008 12:16 PM
grobin54
Mar 27, 2008 06:15 PM
MorrisL03
Sep 16, 2007 10:09 PM
